Listbox
Re: Listbox
Postby RJHollins » Wed May 18, 2016 8:18 am
Hi Spogg,
Yeah ... this is really nice. Working great.
I don't know what additional 'majic' may come about ...
For my little project, I'm SAVING out the array as a TXT file. I've added an AUTOLOAD feature that pulls
the TXT file back in at launch.
Of course, I have a specific use ... but it would be interesting to see what is possible.
8-)
Re: Listbox
Postby Tronic » Thu May 19, 2016 6:49 am
Working on it...
but i have switched to GUI with an vertical scroll-bar.
also coming some feature:
- switched to vertical gui scroll-bar
- Spogg request, is already added as option to restore the last selected items in list
- enable/disable drag reordering
- separate output for current or saved state for the multi-items selected with index and items as [1,RJHollins]
- select by content of item
- other bug fix
soon....
Tronic
Re: Listbox
Postby RJHollins » Thu May 19, 2016 9:39 am
vertical scroll-bar
that would be so nice !
You're really spoiling us Tronic :lol:
An idea/request.
Would be be possible to User configure the TEXT size of the entries. I've been able to make so slight adjustments of your design to handle specifics of the project requirements. These have been simple things like:
1. Overall WIDTH of the text lines. This is really simple to do as is.
But something that would be very elegant ... Making a selection from the master list, and dragging that selection over to populate the other box ... and vs-versa. [drag and drop technique].
Just an idea or two ...
To be clear, I have absolutely no problem with the current working design. Your programming skills are way beyond my ability, and the current version WORKS just fine for my project [but definitely interested in what you cook up].
For my little project, this is the first NON-music related app.To be able to use FS to write other types of apps would be useful. I did wish we had a way to do PRINT-OUTs with FS. Things like a 'Client Database', Client Billing/Invoice could be prime, custom candidates.
Well ... just thinking out loud ...
Big THANKS again TRONIC 8-)
Re: Listbox
Postby Youlean » Sat May 21, 2016 8:01 pm
Nice. Here is green implementation that I made a while ago...
viewtopic.php?f=3&t=3368&p=18069&hilit=youlean#p18069
Youlean
Re: Listbox
Postby Walter Sommerfeld » Sun Dec 11, 2016 12:41 pm
nice Duo Listbox but it has a big BUG in the _r3 update from Tronic:
If the List isn't full(empty row(s) and shows transparent background) you can drag a name into one of these empty rows => ruby error
Please update...
Listbox (tulamide)(tronic_mod).png (140.86 KiB) Viewed 32585 times
Walter Sommerfeld
Re: Listbox
Postby tiffy » Wed Feb 21, 2018 3:53 pm
Hi Tronic, this so cool.
I have only one request...If you are going to keep the Up/Down arrows, would it be possible to make them Auto-repeat i.e. when you click on either one and hold down the mouse button it should simulate multiple mouse clicks.
Thank you so much.
tiffy
Re: Listbox
Postby tiffy » Sun Feb 25, 2018 9:23 am
Thank you so much for this one Tulamide. I downloaded this and forgot to thank you but rather late than never.
I like the nice clean interface of this version i.e. revision 2.
It would be really nice if the Up/Down Arrows can do Auto-repeat for long lists.
tiffy
Re: Listbox
Postby djbrynte » Sun Feb 25, 2018 2:22 pm
hey tulamide do you have a listbox u drag down. i mean a preset manager? im stuck with this drag on side. But im after a preset manager u drag down like in nexus 2. So u can scroll down :) and choose presets :) also this < > change presets - and +. also copy paste or something save presets u kow the basics :) if some one know any pls help me find it :) i need one would be so helpful.
djbrynte
Re: Listbox
Postby tulamide » Tue Feb 27, 2018 11:20 am
tiffy wrote:Thank you so much for this one Tulamide. I downloaded this and forgot to thank you but rather late than never.
I'll have a look at it, but I can only do it for my original version, so that might be a step back, since Tronic added quite some functionality.
Re: Listbox
Postby tulamide » Tue Feb 27, 2018 11:21 am
djbrynte wrote:hey tulamide do you have a listbox u drag down. i mean a preset manager? im stuck with this drag on side. But im after a preset manager u drag down like in nexus 2. So u can scroll down :) and choose presets :) also this < > change presets - and +. also copy paste or something save presets u kow the basics :) if some one know any pls help me find it :) i need one would be so helpful.
No, I haven't. But from my mind it seems that there was such a preset manager somewhere. I remember it having seen in one of the many schematics here. But I can't tell you in which one.
Previous
