Guitar Amp's & Equipment
Postby DigiTonix » Thu Sep 01, 2016 12:43 pm
A&E IMG.jpg (31.54 KiB) Viewed 31665 times
Dear friends, I want to get this theme for guitar Ampsim's.
Can at whom that is initial schemes AmpSims from Ronald Passion, for example such as REVOLUTIONZ, it is possible it them published.
I long searched for them at a forum and on the Internet, but and have not found... 404 absolutly!
And also I have learnt that when that it had been made analogue schemes
For simulation of characteristics ToneStack, and some Electronic Circuit components since SinthMaker, Then they have been lost. Probably at whom that is model of pentodes, or vacuum lamps, or others?
I ask you, to share guitar schemes in this theme if they at you are.
And if they are not present, let's make the!
DigiTonix
Re: Guitar Amp's & Equipment
Postby Nubeat7 » Thu Sep 01, 2016 11:23 pm
Are you using Google translate? I can't unterstand what you are talking about..
Postby nix » Fri Sep 02, 2016 6:17 am
I will up my guitar plugin here,
just clearing it with a wave-shaping coder.
I mainly don't use cabs, mics and amps,
but I like stomps.
I'm hoping to up a chain of effects:
compressor-> distortion ->reverb
Heya NuBeat,
Tonix just wants to start a thread about guitar effects-
How's things?
nix
Postby DigiTonix » Sun Sep 04, 2016 12:17 pm
Hi guys, I do new Rompler with 4 guitars, can to me you will prompt how to make Aftertoach with midi the controller?
This Fender Str...
DigiTonix
Postby Spogg » Sun Sep 04, 2016 12:24 pm
There's an After-touch MIDI Prim called Atouch.
I never used it because I don't have that on my keyboard. You connect it to the MIDI input and it puts out 0-127 so you may need to divide it by 127 to get 0-1 control range.
Postby DigiTonix » Sun Sep 04, 2016 12:38 pm
It seems has understood, it will be necessary to find, thanks Spogg... :)
I could not persuade the employee to give to you Biofuse, sorry :(
But when I will complete the scheme of this plug-in, I will give to you and Nix. Access to mine Yandex Disc, there many such abrupt schemes and is a lot of GUI... Which will be useful to you. (More which 200 here is not present) And you can change them somehow, this all my schems...
DigiTonix
Postby DigiTonix » Tue Sep 06, 2016 4:05 am
Erasov GT-1 (Russian Ibanez TS Clone)
Erasov GT-1 VST.jpg (60.6 KiB) Viewed 31538 times
1) Aliasing! How anti aliasig?
2) Very Bad Filters... How made analog (Resistor + Capacitor) filters
3) How make OP-Amp for Clamping simulation PLEASE!!!
V0.0.1 DL: https://www.dropbox.com/s/hgfh48yexs4k5 ... 1.fsm?dl=0
Who will help to understand with filters, Ampsims, to make this pedal to the end (It is very necessary to me) To make as RP...???
DigiTonix
Postby DigiTonix » Sat Sep 10, 2016 1:43 pm
Basic Harmonic Sinthesis for AmpSim...
This algorhitm using many VST Developer's... AmpliTube, Vadim Taranov, Softube, end others Developer's...
More Coment's Please!!!
Harmonic Sinthesis.fsm
(_*_)
(116.63 KiB) Downloaded 1201 times
DigiTonix
Postby tulamide » Sat Sep 10, 2016 3:41 pm
DigiTonix wrote:More Coment's Please!!!
I would love to comment, but I'm afraid only native-english-speakers are able to. I already have difficulties to translate normal english to german, but you don't even use normal english. I know that english isn't very popular in russia, but you need to improve just a little bit. If you could use english syntax at least, that would help me so much understanding your posts.
Postby Spogg » Sat Sep 10, 2016 3:47 pm
Just wondering... how well does Google translate deal with Russian to English?
