Synthmaker bundle
Re: Synthmaker bundle
Postby RJHollins » Sat Oct 29, 2016 8:32 am
I've been staying out of this thread... but following it closely.
Why? Was not much of a 'synth' guy. I love em, recorded many synths over my career.
Tons of respect to the Guys creating with them.
My gig is an Audio Engineer. We do love the 'twisting of knobs' ... but I would probably fall into the 'Well of Synths',
and not get my audio work done :|
great looking designs Guys ... must resist :P
Postby k brown » Sat Oct 29, 2016 8:43 am
Hi Spogg -
It's not ideal I suppose, but folks could just click on the link and peruse the Screenshots folder and see if they find anything they hadn't downloaded yet?
Added today:
mOdyCat (three-osc Cat/Ody mashup)
Matrix-SixFM (Matrix-Six wFM osc)
Multipoly (Multimoog)
Rolend Block-8 with patch cables
Kroma Duette (VERY stripped-down Rhodes Chroma)
Postby Spogg » Sat Oct 29, 2016 8:51 am
k brown wrote:It's not ideal I suppose, but folks could just click on the link and peruse the Screenshots folder and see if they find anything they hadn't downloaded yet?
OK then! Great idea. I can use the screenshots folder as a basis for my collage too. I'll be onto this in the next few days and I'll post here when it's up and you can see if you want anything changed or added. Excellent :D
Postby k brown » Sun Oct 30, 2016 7:06 am
This isn't a new one or a massive re-vamp, but since it's probably the most complex and flexible little monster I've ever built, I thought I'd let everyone know that I finally got 'round to param-naming Atticus , my spin on u-he's Bazille, but hopefully a little easier on the CPU. It doesn't have all of Bazille's features and the oscs and mixer/filters are rather different, but it's still a beast!
-Four analog/digital hybrid oscillators.
-Two filters with internal mixers.
-Two VCAs.
-Two LFOs.
-sLFO.
-Four EGs.
-Two 'Multiplex's.
-CV Adder/Lag
-Reverb/Phorus
-Delay/Chorus (Chorus sucks, though)
Postby Knob Twiddler » Sun Oct 30, 2016 11:26 pm
Can someone help with this ?
I loaded the Voyager version called Cassini into Flowstone and without any changing, I exported it out as a VST but the XY-Module isn't working anymore in the exported VST. What can be the cause?
Knob Twiddler
Postby cakebox » Mon Oct 31, 2016 6:20 am
Knob Twiddler wrote:Can someone help with this ?
Did you load the .osm from the original bundle, or the .fsm from Spogg's upload?
And is the xy-pad working inside FS?
cakebox
Postby k brown » Mon Oct 31, 2016 6:53 am
And does Spogg or anyone else know how to add preset capabilty to an XY pad - all the ones I have don't have this and my feeble attempts have not been successful.
Postby Spogg » Mon Oct 31, 2016 9:53 am
k brown wrote:And does Spogg or anyone else know how to add preset capabilty to an XY pad - all the ones I have don't have this and my feeble attempts have not been successful.
Here's my collection of X-Y pads. All of them have preset handling and I've included a preset manager to demo.
This is in FSM format. I tried changing the extension to OSM but Synthmaker can't deal with it.
Maybe if you can have a look in Flowstone you could adapt the technique to SM.
EDIT: I found 2 in Synthmaker format which work with presets with a manager to demo.
5609_More GUI Kit - X-Y Pad with presets.osm
(16.21 KiB) Downloaded 1045 times
390_X-Y Pad with presets.osm
(11.43 KiB) Downloaded 1017 times
X-Y pads with preset handling.fsm
(235.32 KiB) Downloaded 1038 times
Postby k brown » Mon Oct 31, 2016 11:02 am
Thank you so much - you're about to make some people very happy!
Postby Knob Twiddler » Mon Oct 31, 2016 1:32 pm
Hello Spogg,
After doing the parameter fixing on the Cassini plugin, I noticed that the xy module was not working anymore after exporting to VST format. As a test I did an export on the original file from K.Brown (without my changes)and there it also fails to work. It works fine in Reaper with his VST version.
Now after replacing the module with two of the onces you uploaded, it seems to work again, untill I start moving the module to the correct place with the toggle edit panel. When you move it, the mousefocus is no longer on the circle of the module, like it forgets where the circle is positioned. I hope this makes sense to you.
Here is an export of the .fsm file with the working module but not in the right place:
https://drive.google.com/file/d/0B_GTGf ... sp=sharing
Knob Twiddler
