MIDI IN to knob and OUT
I'm very very new at using Flowstone. Checked some tutorials, read the guide.pdf ten times, tried some but couldnt get further then getting midi out of an knob.
My question is. How can i make an patch with does as follows?
MIDI IN ----- animated knob* ------- MIDI OUT
* = 1) how to make your own knob skin?
2) how to change the input and output value of the knobs (0-127 midi)
Thanks in advance!
Thanks in advance!
- RowinGrunder
Re: MIDI IN to knob and OUT
Welcome to the forum.
First, the easy way! Download yourself a free little app' called 'KnobMan'. This is an indispensable little tool tailor made for creating the kind of 'animation strips' used by the "Knob - animated" (and a whole load of other GUI app's).
You could also use any other image editor to create a long strip of square 'frames' each showing the knob in a different position - but Knobman really does make it a whole lot easier.
Then simply load this bitmap into the knob from the 'properties' page (click the little 'P' in the corner of the knob GUI). Then set the 'cell size' property to the size of one square "animation frames" from the bitmap strip, and the inner workings of the module will take care of everything else.
There are other ways too - such as taking a simple bitmap and rotating it, or using FlowStone's vector graphics - but those are trickier to program, and don't have ready made modules when you first install FlowStone (worth a forum search though - there are a few examples floating around).
The same 'Knob - animated' is already set up to receive MIDI messages (also set up in the 'properties' page of the module). But the MIDI input is 'hidden' by using a wireless link - so you need a wireless transmitter connected to your MIDI input device to send the messages in.
The MIDI output part is easiest done with a couple of extra parts...
1) In the knob properties, set the knob to have a min, max of 0...127
2) Grab yourself a 'MIDI Event' primitive
3) Connect the value '176' to the 'Status' input of the MIDI event - this is the code for "Controller Message"
4) Connect whatever value 1...16 to the channel input to set the MIDI channel to send on.
5) The 'Data1' input takes the number of the controller that you want to send
6) Connect 'Data2' to the knob for setting the controller value.
7) Connect the knob also to the 'Send event' input to tell the primitive when to make a new output. You must connect this AFTER connecting data2, or things will happen in the wrong order when the knob is moved!
A "Changed" module set to use integers, between the knob and 'MIDI Event' will also be useful - it will help to prevent too many MIDI messages being sent out faster than your synth can handle.
Here's all of that put together in a simple example...
There are other ways to do this too, for example writing the equivalent of the 'MIDI Event' into the Ruby code of the knob - but the method above is easiest if you want quick results before you get stuck into Ruby programming etc.
RowinGrunder wrote:1) how to make your own knob skin?
RowinGrunder wrote:2) how to change the input and output value of the knobs (0-127 midi)
First of all! Huge thanks for pointing out some interesting idea's, also the fact you're sharing an .fms is great! Thanks. Nevertheless i have a problem? Why do i get to see my midi stuff when using MIDI In --> Split .. but not in your demo?
http://i.imgur.com/6PBQI.png
*update.
Its controlling my Akai APC40 knob but the knob in FlowStone won't turn when i use my APC40 knob.
*update2.
nvm. works. just needed to give input CC16 at 'properties panel' of the Knob - animated object haha. cool.
*update.
*update2.
- RowinGrunder
what do i need to make an .vst? the option .exe works, but in the tutorial i saw this.
can u post me the .fsm so that i can use it as a plugin? now i getting used to work with the midi stuff. thanks again!
- RowinGrunder
I think you found the answer with that snippet from the manual.
The VST option will show on a module,
if it has the right ins and outs,
ie. blue audio and MIDI
Welcome!!
Welcome!!
nix - Posts: 817
Hello Rowan
If it is a midi controller you are making and wish to export it in a vst effect, all you need to do is add two dummy audio outs as well as your midi in\outs!
here is an updated schematic
hope that helps
hope that helps
- Jay
RowinGrunder wrote:Why do i get to see my midi stuff when using MIDI In --> Split .. but not in your demo?
Aah, sorry - there is a small bug in the current version of FC that prevents MIDI->text from working just at the moment.I I completely forgot about that because I've just been Beta testing a little patch for it - so it will definitely be fixed in the next release!!
Hi, I'm new at this too, I want to control a external FX unit with midi commands.
It supports NRPN commands, but I don't know how to make knobs and switchs to send this kind o commands.
I'm reading the manual and trying, but I have no clue, a little help point me on basics will be great!
How I make a button that sends one state when (true) and other when (false)? So I can turn on a button or turn it of.
The knob example is great! I'm trying to understand all yet heheh.
I have to send RNPN messages like this
$B0 $62 $4A
$B0 $63 $03
$B0 $06 $40
$B0 $38 $00
I see that I have to leave at least a tick between each one, too many things and I'm a completely noob! Where to start! I'm a designer and newbie into programming..help
$B0 $62 $4A
$B0 $63 $03
$B0 $06 $40
$B0 $38 $00
skull - Posts: 18
Here is a 2 state switch.
You can put whatever text in the text boxes,
and switch between them.
Hope helps, Nick
Welcome to our corner of the internet!
nix - Posts: 817
Thanks Nix for your reply and welcome!, I'm lost in the part where I take this true'false variable and shoot a trigger to send a midi nrpn message. I saw some examples of nrpn, but I'm too new, I need a switch that triggers a midi CC, but the fx unit I have uses more controllers if I use NRPN.
skull - Posts: 18
Users browsing this forum: No registered users and 73 guests
