Slower Largescope
• Page 1 of 3 • 1, 2, 3
Slower Largescope
Hi, I am trying to do a largescope (display) for my compressor. I made it, but is too fast... Any idea how to slow it down? Thanks!
Here is the largescope with compressor.
- compressor_largescope.fsm
- (739.27 KiB) Downloaded 973 times
- Wassaka
Re: Slower Largescope
You need to take a longer window time somehow mate
nix - Posts: 817
nix wrote:You need to take a longer window time somehow mate
Yeah, but I have no idea how to do that
- Wassaka
Hello Wassaka ,
How does this work for you? You can choose a value that works for you.
Cheers, BobF
Cheers, BobF
- BobF
@BobF
Thanks you for the reply, but I'm looking for a way that slows down in speed, not in FPS.
- I made a version that works just as I want it, but unfortunately it is modifying the SAMPLERATE, and that destroys the sound... Is there a way to do the same but without modifing the SR?
Here is the file (dowsn't work on FLSTUDIO Flowstone, [only in .exe] )
- compressor_largescope_Solution1.fsm
- (741.79 KiB) Downloaded 1019 times
- Wassaka
That tells you resolution is key.
Reducing the samplerate means you reduce the amount of data per second. So instead of reducing the sample rate, reduce the amount of data per second for the scope only. Less data means less change, less change means slower movement impression.
He is using the mono to graph primitive, and the "INS" input (number of samples to take) has an upper limit, so he cant increase the size.
- adamszabo
I do know this isn't what you want exactly but it does allow you to examine the waveform using the run/hold button...
- compressor_largescope-7spogged run-hold.fsm
- (1.44 MiB) Downloaded 936 times
Spogg - Posts: 3358
adamszabo wrote:He is using the mono to graph primitive, and the "INS" input (number of samples to take) has an upper limit, so he cant increase the size.
Exactly, the limit of samples per second is 44100. If you choose a smaller value of samples to this the graph, it will go even faster.
- Wassaka
Wassaka wrote:adamszabo wrote:He is using the mono to graph primitive, and the "INS" input (number of samples to take) has an upper limit, so he cant increase the size.
I'm not sure if the limit is 44100, or the samplerate of the project (which makes more sense).
If you use a smaller value, you don't have less data per second, since it still runs at samplerate. You could either buffer data to get away from samplerate and lower the amount of data per second, or leave out data while maintaining the samplerate speed.
view displays x amount of data
stream provides y amount of data
if y < x wait until y = x -> results in slower movement
if y >= x just take a portion of y, y/z, wait until y/z = x -> results in slower movement
