Soft clipper
Soft clipper
i need create soft clipper (distortion)
The curve and harmonics are very similar to free plugin Gclip.
I found a formula that gives the right harmonics
where alpha 2.5
but 2 power and 2 divisions per sample
Can there is another way to get this curve?
i try in desmos
https://www.desmos.com/calculator/ujkvajglhj
I did not succeed, can anyone have more experience in mathematics?
sample / pow(1 + pow(fabs(sample), alpha), 1.0f / alpha)
where alpha 2.5
i try in desmos
- Logado
Re: Soft clipper
That's very close to the good old tanh(x). I'm not familiar with that plugin but I assume that's what it's using since that function is very popular.
Now tanh itself is also expensive to compute, but you can get away with very rough polynomial approximations.
You can find some on google.
- TheOm
Re: Soft clipper
There are fast stream functions over at FS Guru which you could use. Alternatively, try
which is even closer to your formula than tanh(x).
Edit: Sorry if this information was cursory. Here is a schematic with optimised transfer curves.
y = x/sqrt(1 + x^2)
CustomTF.fsm- (1.24 MiB) Downloaded 1630 times
Re: Soft clipper
thanks for tips, distortion is an interesting area, so much magic happens here
- Logado
Re: Soft clipper
Hello Logado,
DO some searches on the forum, but just not for distortion, but clipper, wave shapers, fuzz, square wave (etc), rectifiers, and so on. You will find many examples of magic. Feed them with a sine wave and then out to a windowed FFT display and you can view the harmonics.
Have fun.
Cheers, BobF.....
Have fun.
Cheers, BobF.....
- BobF
Re: Soft clipper
BobF wrote:Hello Logado,
Have fun.
Cheers, BobF.....
I think I've seen ~90% of osm files from the forum
- Logado
