Simple DSP question re code execution with no output
Postby Spogg » Tue Apr 11, 2017 4:01 pm
Hi!
Simple DSP question: Is the whole of a DSP code block evaluated every sample even if some of the outputs aren’t connected?
For example, a state variable filter where only the high pass output is connected to anything.
Re: Simple DSP question re code execution with no output
Postby adamszabo » Tue Apr 11, 2017 5:32 pm
If you only have open output from the DSP code box then I believe its not calculated. If you have multiple output from it and even if you only connect one thing to it, the others will be calculated as well.
adamszabo
Return to DSP
