FIR filter
FIR filter
I want to process the convolution of an audio input signal with an impulse response. How can I create a FIR filter? Can I introduced the coefficients by using a text file?
Thanks!
Thanks!
- lizard4mg
Re: FIR filter
If you want to make your own filter then you can use the DSP code component.
If you look inside something like the Moog Filter you will see the DSP code component used at the bottom level.
- Embedded
Re: FIR filter
MYCO released a convolver quite a while ago on the SM forum.. I didn't see it available here yet so check the sm forum search for MYCO and real time convolution.
edit:
It might have been matti that did that convolver?
edit:
- VPDannyMan
Re: FIR filter
VPDannyMan wrote:MYCO released a convolver quite a while ago on the SM forum.. I didn't see it available here yet so check the sm forum search for MYCO and real time convolution.
edit:
Yep, me. Hi
Though it seems the files haven't been online for a while now. I'll have to see if i have them somewhere.
Edit: I read through the original thread from SM forums (as i don't remember where it was left) and i think it might not be a very good example for FS. If i rewrote it with FS specific tricks it might work better. Maybe a project for some rainy day
- matti
Users browsing this forum: No registered users and 55 guests
