A little Hand notepad
Postby Tepeix » Thu Jun 01, 2023 12:15 pm
A little hand notepad.
Sometime, i get idea that i want to note but it need some graphic.
I could write it on a paper, but the paper have chance to get lost with other ones.
It's more easy to have those note inside the flowstone schematic they are related.
So i build this very simple notepad.. It could be perfected but do the job.
The graphic will stay in memory but is erased when resizing the window.
It's also possible to erase part with Ctrl down.
handnotepad.fsm
(16.8 KiB) Downloaded 511 times
Tepeix
Re: A little Hand notepad
Postby billv » Fri Jun 02, 2023 8:49 am
billv
Postby Tepeix » Tue Jun 06, 2023 9:26 pm
Interesting and very more advanced !
But for fast notation i stay on mine, even if there's a lot to perfect..
But i'm happy with this new version. Schematic are better organised.
Write are more smooth, combining an ellipse and a line.
And some color selection using shift key.)
Hanpadd2.fsm
(7.94 KiB) Downloaded 506 times
Tepeix
Postby billv » Thu Jun 08, 2023 10:33 am
First thing i did was to test your mouse capture, by drawing really fast..and holy f##K...it works.. :o
Unbelievable!...I say this because i went to hell and back trying to get accurate mouse capture in Pixel Art.
Trog gave me all this "Psuedo code"....it was a real "head f@@k..i'll never forget it...So well done... :D
billv
Postby Tepeix » Mon Jun 12, 2023 11:39 am
Yep, line + ellipse works fine !)
I try to upgrade it, making only ellipse or line depending on the distance..
But finally it's better to always have both of them.
My error was to use different size, for some reason i was thinking it was necessary,
but they merge even better with the same.
Also a little upgrade, we could also change the size of the line using shift and drag.
handPadd V3.fsm
(36.21 KiB) Downloaded 523 times
Tepeix
Users browsing this forum: Majestic-12 [Bot] and 14 guests
