Weird Int prim behaviour for Pitch to Freq. WTF?
Postby Spogg » Sat Jul 01, 2017 10:31 am
Help! I’m baffled by this!
Pitch to Freq issue:
If I use a green value from a knob to set a note number and put an Int prim on it, the pitch should increase in whole semi-tone steps but it ignores the value from the Int prim and operates smoothly with no exact intervals. Unless I attach just the output from a de-zip to the P-F input, then the Int works. This is the same for Martin’s Pitch to Freq converter.
See the note in the attached schematic.
WTF?
Green Int not working 1.fsm
(127.69 KiB) Downloaded 868 times
Re: Weird Int prim behaviour for Pitch to Freq. WTF?
Postby martinvicanek » Sat Jul 01, 2017 12:17 pm
Works OK here: Take your schematic as it is, turn knob, get semitone schanges.
Postby Spogg » Sat Jul 01, 2017 12:26 pm
Thanks for checking this out Martin.
I was about to delete the post because I rebooted the PC and now it works. I'd previously closed and re-opened FS and the issue remained, so some corruption from FS seems to have stayed in memory even with the program closed.
It's the only explanation I can think of.
I guess I should have tried a reboot before asking for help :oops:
Thanks again.
Users browsing this forum: Google [Bot] and 71 guests
