Slower Largescope
Re: Slower Largescope
Postby lalalandsynth » Tue Jul 04, 2017 7:53 pm
This is all kinds of weird. Did this work perfectly for you ?
Maybe I am just misunderstanding this and it should not start at the beginning of the scope window ?
That would explain a lot?
I hit play and it shows up here .
weird 1.jpg (38.93 KiB) Viewed 13254 times
I hit play again and it shows up here.
Weird 2.jpg (36.26 KiB) Viewed 13254 times
lalalandsynth
Postby Wassaka » Tue Jul 04, 2017 11:55 pm
It works well for me. I made a system which when the song is played, resets the scan, causing it to be drawn as soon as the beat starts ... But this system requires DAW information ... I tested it in FL Studio and it works perfectly ...
Anyway I did a second version with some changes. Let's see if this works for you.
Meter Tempo Synced-V2.fsm
(572.13 KiB) Downloaded 936 times
Wassaka
Postby lalalandsynth » Wed Jul 05, 2017 9:23 am
Cool will test , to be clear when you say drawn when the beat starts , that means its drawn at the start of the window , far left ?
lalalandsynth
Postby lalalandsynth » Wed Jul 05, 2017 12:19 pm
The "problem" for me is getting it to start at the beginning of the scope window.
It is not clear to me if it should do that and just not working or if its designed like this ?
Sync scope.jpg (57.86 KiB) Viewed 13237 times
lalalandsynth
Postby lalalandsynth » Sun Aug 27, 2017 2:19 pm
Still trying to get this to work , but using this approach I cannot get the scope to start at the beginning of the scope window. Basically what I want to achieve is when looping say 2 bars in the daw it will show 2 bars of waveform.
So not a scrolling display and one where it starts drawing at the beginning of the window.
lalalandsynth
Previous
