What are some good filters?
Postby lalalandsynth » Tue Jul 11, 2017 4:41 pm
I have been trying out some filters , found some ok ones , mostly a distorted 3 pole.
What I found with most lowpass filter , even the 4 pole 24db ones is that they do not really close down enough.
Always some low end leaking through . Is this some quirk of FS filters or am I just trying out some bad examples?
Any filter wisdom you want to share ?
lalalandsynth
Re: What are some good filters?
Postby martinvicanek » Wed Jul 12, 2017 7:51 pm
Hm, lowpass filters are designed to pass low frequencies, so what do you mean by "low end leaking through"? Which filters ahve you tried in which setup? There is no limitation in FS that would prevent filters from having a good stopband rejection.
Postby lalalandsynth » Wed Jul 12, 2017 8:51 pm
Like this one , where I cannot get the cutoff point low enough , probably something I am missing.
Oh...nevermind ,found what I was doing wrong, had to be.
Tripper.fsm
(641.47 KiB) Downloaded 869 times
lalalandsynth
Users browsing this forum: Google [Bot] and 68 guests
