CSV2Display(Datasheetview)
Postby Pali64 » Wed Jul 19, 2017 8:05 am
Hello forum members
Since I have found no tool, which represents csv files I have written myself one.
It mainly consists of ruby code.
For a better understanding, I have just designed it as a module.
If you need it, you can split it accordingly and, for example, to use Lyric texts in MIDI.
The module [CSVtoARRAYa.fsm] was created under "FlowStone 3.0.9 Beta 2"
The module [CSVtoARRAY.fsm] was created under "FlowStone 3.0.8"
I'll later add more tools as soon as they run error-free
Greetings Pali64
CSVtoARRAY.fsm
FlowStone 3.0.8
(10.16 KiB) Downloaded 1155 times
CSVtoARRAYa.fsm
Work at FlowStone 3.0.9 Beta 2
(10.32 KiB) Downloaded 1089 times
We made Keyboard and Synthesizer for you
so all Poaple can kommunicate with a Language to all poaple understand
Music is the nicest work in World ;)
Pali64
Re: CSV2Display(Datasheetview)
Postby Spogg » Wed Jul 19, 2017 8:13 am
It looks impressive!
What are you using this for in practical terms? Is there a music-related use for it?
Postby Pali64 » Wed Jul 19, 2017 8:39 am
Hello Spogg
Spogg wrote:.... Is there a music-related use for it?....
Yes I use it to display Lyric from MIDI files synchronized in bars(MIDI clock).
To do this, enter the bars of the sung syllables on the [Row in]
The sung text passages with [,] separated from the midi file on [CSV_In]
This can be placed as a semi-transparent text field over the notation
Greetings Pali64
Pali64
Postby Spogg » Wed Jul 19, 2017 8:56 am
Fascinating! And you did mention lyrics in the original post.
I wouldn't mind seeing a screenshot or something to illustrate what you mean.
I had thought that CSV was really just for diaries and address books and so forth.
Thanks for sharing this unusual project. Another diverse application of Flowstone, always appreciated.
Postby Pali64 » Fri Jul 21, 2017 12:21 pm
Hello Spogg
Here is an useful Example to use as a CSV Databankviewer
I think help an Alien and much other to Understanding where to do :D
Greetings Pali64
CSVfileviewer.fsm
CSV Databankviewer in FlowStone 3.0.8
(1.15 MiB) Downloaded 1060 times
Pali64
