FFT question
FFT question
Postby Lex248 » Mon Sep 18, 2017 7:30 am
Hi, all.
On the picture example of work of FFT. Whether it is possible to get access to every period of a signal separately? May be convolution?
Sorry, I bad speak english.
My plug-ins http://nalexsoft.blogspot.com/
Lex248
Re: FFT question
Postby martinvicanek » Mon Sep 18, 2017 9:35 pm
Lex, we need more information.
What do you mean by "access to every period of a signal separately"?
Do you want to take the Fourier Transform of one period?
Why would you want to do that?
What is the context?
Re: FFT question
Postby Lex248 » Wed Sep 20, 2017 9:30 am
For example, I want to make so through FFT, but standard methods don't allow to make so.
Lex248
Re: FFT question
Postby martinvicanek » Thu Sep 21, 2017 7:04 pm
If the signal is as simple as in your picture, then you just need to check for zero crossings to determine the period.
It is still not obvious to me why you would need a Fourier transform to zero out one signal period. :?:
Re: FFT question
Postby Lex248 » Thu Sep 21, 2017 7:56 pm
The signal will be not simple. I need it for improving of my plug-in "P-Filter - Positional Filter". Standard methods of processing of FFT create artifacts, wrong determination of a position. High frequencies of a signal give many uncontrollable periods. I need control over every period of each frequency of FFT image, if it is possible. It something like several thousands of band pass filters in real time.
Lex248
Re: FFT question
Postby martinvicanek » Thu Sep 21, 2017 10:39 pm
If I understand your concern correctly, the standard way to deal with it is windowing and overlap-add.
That is possible. It's what happens in my FFT vocoder plugin. if your filter is not very steep you may get away with simply multiplying the spectrum by your filter response curve and IFFT - that's it.
Re: FFT question
Postby Lex248 » Fri Sep 22, 2017 3:01 pm
Thank you for help, Martin. I am familiar with your FFT vocoder, but to me is unclear as it works and as I can apply it in the purposes. Maybe there is a block diagram? Still you use mono4, and it is undesirable for me.
Lex248
Re: FFT question
Postby martinvicanek » Fri Sep 22, 2017 11:40 pm
People tend to think of an FFT representation in terms of a graphic equalizer, where you can simply multiply each bin by its corresponding slider value, then simply inverse FFT the result and that's it:
That might work if your filter curve is very moderate.
However, the correct way of doing it is based on linear convolution.:
You first IFFT your filter curve to obtain an impulse response (IR). Theen you apply a circular shift so the bulk of the IR is at the center of your frame, and apply a window function to avaid border artifacts. Then you convolve your signal with the windowed IR.
Re: FFT question
Postby Lex248 » Sat Sep 23, 2017 7:01 am
The problem is that I have no constant filter curve. It depends on a signal and changes according to it.
Lex248
Re: FFT question
Postby martinvicanek » Sat Sep 23, 2017 11:42 am
No problem, just keep updating your IR as you go. Use overlapp and add to avoid sudden changes.
Return to DSP
