5 x foldback
5 x foldback
Postby Nubeat7 » Wed Nov 29, 2017 3:27 pm
hello, actually i'm experimenting with foldback and i'm not sure whats the best way to do it.
i also found out that there are often just one side (mostly the positive part) is folded while the other is not..
here is schematic with 5 stages of folding back from a threshold level and back up again when it reaches the zero level.
My Question, is this a common way to do it? ist there a better algorithm? and i didn't find some good maths to fix the volume in a proper way....
foldback.fsm
(516.32 KiB) Downloaded 1368 times
Re: 5 x foldback
Postby Spogg » Wed Nov 29, 2017 5:40 pm
This topic came up some time ago and if you read from the link below onwards, you'll see some solutions to look over:
viewtopic.php?f=3&t=5258&hilit=wave+folder&start=20#p26356
Hope this helps...
Re: 5 x foldback
Postby Nubeat7 » Thu Nov 30, 2017 10:32 pm
oh great, thanks spogg :)
Return to DSP
