HELP double selection needed to trigger
in the schematic the selector needs the items selected TWICE befor it loads the correct float value, how do i make it work with one selection, and am i missing somthing?? any help is greatly apreciated
- rockaxe55
Re: HELP double selection needed to trigger
Hello!
You had a trigger problem
If you read out with the stringtrigger the trigger will:
readout the array and change the index - so the correct value is read out if you send the next trigger (your 2nd selection in selector)
So to get it corregted you allways have to:
Change index - then "Get" trigger.
I have the corrected version here
array generator help-corrected.fsm- (131.74 KiB) Downloaded 968 times
chackl - Posts: 233
thankyou chackl, for such a fast response, your help is much apreciated
- rockaxe55
you'r welcome
chackl - Posts: 233
