Digital Logic
• Page 1 of 3 • 1, 2, 3
Digital Logic
Hello Gang,
This is a collection of digital logic gates and flip flops, plus a few counters and miscellaneous others. If you are not familiar with digital logic, just Google it. There are many, many web sights that will explain it in detail. With just the gates alone you can create hundreds of other logic functions (again check the net). Just take a look inside one of the flip flops or counters. By combining gates and flip flops , and etc , you can you can create all the digital logic you can find on the net. This includes TTL logic, CMOS logic, and more. What can all this do for you? One example is flip flops can be made to divide square waves. Yes, square waves only. Digital logic is defined as a 1 or a zero. The outputs of these devices only swing from 0 to 1. If you need plus and minus one I have provided the module Bobs 0 to 1 to +- 1 that will do the conversion. Also if you create any new logic modules you will need to add the modifier 0 and 1 only provided by MyCo (thanks MyCO). Again look inside some of the modules. Well that's it! Really hope some of you can put these to good use. If you do create any new logic modules or anything else that uses them, PLEASE share them and have fun.
P.S., I am calling this part 1, as I am always working on some new logic myself.
Later then, BobF.....
- BobF
Re: Digital Logic
Awesome, thanks Bob! I will most likely put some of these to similar noisy uses as I did your VC divider.
- noisenerd
Re: Digital Logic
Thanks Bob!
Straight into my toolbox.
Tell you what, how about doing all this stuff in green as well, for control purposes?
Maybe I'm asking too much but I think it would be useful...
Thanks again for sharing this work.
Re: Digital Logic
Hello gang,
Ok Spogg, here you go! These are NOT all mine just found them probably at the old Synth maker forum.
Of course using standard digital logic as before you could make many more modules. I will try to add some more as I have time. The ones I created of course say Bobs xxx whatever the module is.
Well everyone, please use, comment, and enjoy.
- BobF
Re: Digital Logic
Hello FS-community,
I'm coming from the "Max-msp-Jitter" world and looking for a simulation of the CMOS-IC 4017 (Johnson Decade Counter) to built an emulation of the Stepsequencer from the Yamaha-CS 30
thanks for help and solutions
TSt - Posts: 10
Re: Digital Logic
Hi Bob,
This just turned up, massive collection of Digital Logic, back to school for me !
Thanks for posting !
ROXY
ROXY
rocknrollkat - Posts: 213
Re: Digital Logic
Hello TSt,
Have NOT created a cd4017 as yet, maybe sometime down the road if I get some free time! I did have this laying around in my tool box. Never posted it so maybe you could do something with it. If you do PLEASE post your results on the forum.
Take care, BobF.....
- BobF
Re: Digital Logic
Very koooool ripple counter !
Everybody likes LEDs !
Seriously, amazing work, Bob !
ROXY
ROXY
Re: Digital Logic
thank you BobF for this gift,
cheers
TSt
cheers
TSt
TSt - Posts: 10
Re: Digital Logic
after some tries, here the 1st result of a 4017 simulation - but it's not finished,
the internal architecture of the HEF4017B was the model
a little bit tricky seems the realisation of the reset procedure,
in the CS-30 stepseq we've got the choice between 1 - 8 steps (perhaps an additional reset input in the 4017 is needed?)
these square red buttons and toggle designed after the orig. seq switches of the CS-30 seq.
thanks for further help and solutions
TSt
TSt
testlab_4017_1st_exp_.osm- (526.63 KiB) Downloaded 1167 times
TSt - Posts: 10
