Ruby constants
Re: Ruby constants
Postby digitalwhitebyte » Sat Feb 09, 2013 3:47 am
Regarding the use of self
I do not know, maybe I misunderstood what you wanted to do, but what I mean is displayed in the attached file.
test_const.fsm
(381 Bytes) Downloaded 956 times
digitalwhitebyte
Re: Ruby constants
Postby MyCo » Sat Feb 09, 2013 5:02 am
digitalwhitebyte wrote:I do not know, maybe I misunderstood what you wanted to do, but what I mean is displayed in the attached file.
I don't get it, what do you want to demonstrate with this?
What I wanted was a constant that only exists inside one single RubyEdit... you can do that with a static or an instance method, in this case it doesn't matter. But why use static? it is longer and has no advantage at all
MyCo
Re: Ruby constants
Postby digitalwhitebyte » Sat Feb 09, 2013 5:40 am
HAHA long debate on the "self"
I know that I tell you, you already know,
but have another point of view on this clarifies the ideas too.
however, I understood this from my readings, in ruby, static method are called class methods
def self.method_name
defines a class method
def method_name
defines an instance method
digitalwhitebyte
Re: Ruby constants
Postby trogluddite » Sat Feb 09, 2013 1:56 pm
digitalwhitebyte wrote:def self.method_name
def method_name
If you are within the namespace of a class, then yes that is correct...
class myKlass
  # in here, self = myKlass
  def self.method
     # in here, self = myKlass.
  def method
     # in here, self=the object instance
But if it is not wrapped in a class definition, then self = the RubyEdit instance, so you are defining a singleton method of the RubyEdit object...
def self.hello
"hello"
def goodbye
"goodbye"
hello #=> "hello"
goodbye #=> "goodbye"
singleton_methods #=> ":loadState, :saveState, :hello, :goodbye"
So if you are not within a Class/Module definition context, adding 'self' makes no difference, because the RubyEdit instance is the implicit 'self' anyway.
The class in the RubyEdit instance context is a proxy singleton class for the individual object which inherits from the RubyEdit base class. You can do something similar for any object...
a = "hello"
b = "goodbye"
a.define_singleton_method(:ouch){"a is #{self}, ouch"}
a.ouch  #=> "a is hello, ouch"
b.ouch #=> <undefined method "ouch" for "goodbye"; String>
So we've added a method that only applies to string 'a' - which will also continue to respond to any other String instance methods, as String is still its superclass. String 'b' remains unaffected because the base class has not changed in any way.
This is effectively what is happening when we create a "classless" definition inside a Ruby primitive - everything is executed in the context of the instance, not the class.
This is actually pretty clever work by the DSPr boys - it's what allows every Ruby editor access to all of the built-in methods, while letting us define our own methods which are only visible to the individual primitive.
The next step will be to similarly isolate plugins/schematics from each other to avoid class/nodule sharing- I've emailed Malc with a couple of ideas for how this might be achieved, and he sounded positive about it, so I'm hopeful that we'll see that improved some time soon.
Previous
cron
