Going from 3.08.1 to 3.06
• Page 2 of 3 • 1, 2, 3
Re: Going from 3.08.1 to 3.06
tula, I tried to delete this keyborad and use Nubeat's one. But still having problems with the ruby module. It doesn't works "after load", but only when I switch off and then on it's ruby primitive. That's strange. Am I doing something worng?
kortezzzz - Posts: 763
kortezzzz wrote:tula, I tried to delete this keyborad and use Nubeat's one. But still having problems with the ruby module. It doesn't works "after load", but only when I switch off and then on it's ruby primitive. That's strange. Am I doing something worng?
I so hoped, it would work right out of the box! I'll have a look at it, maybe this time it's something in my module.
EDIT: Now that's strange indeed. I couldn't reproduce your issue. Please check the attached schematic. Open it and right away click a note on the keyboard. Works without issue for me, each time.
- tulamide's detect all notes module test 01.fsm
- (18.28 KiB) Downloaded 982 times
Now it's perfect. So elegant...
I usually afraid of Ruby and prefer the green, but this time, the high value winks too seductively
Thank you.
Thank you.
tula, there is one more problem:
Key E is not working after load. Only after switching the ruby primitive off and then on
any suggestions?
any suggestions?
I don't know what else I could say, other than what I already did. I don't have any of these issues (see my last post), so chances are, you introduce them by something you do in your schematic. Remember, if you don't provide a midi stream that's following the midi protocol, you might end up with issues. So avoid anything that's not allowed, like Note Offs without prior Note Ons, sending several Note Ons for the same key, etc.
Ok, thanks, tula.
And yes, you are right. It works great in your uploaded schematic, but after adding it to my toolbox and then to my schematic, the problem occurs. It must be related somehow to my schematic. But there is no significant difference between your and mine midi connections. Same keyboard, same midi in connection.
Another little question: Is there any ruby commamd that can switch the ruby primitive off and them on (by using timer) or ruby commands have no premmision to that feature? because shutting off then on or just a slight meesing with the code fixes the issue.
Sorry to interfere but is there any chance you could upload a demo schematic that shows the issue?
Tula’s module works fine for me (in 3.06) …
Spogg - Posts: 3358
you were right, guys. I found the problem. I messed up with midi protocol while trying to split the keyboard into 2 ranges, by using a roby module. The outcoming midi array on "after load" was wrong. so I just substituted it with a green one and no more errors
Thanks!
Thanks!
OK, so back on topic now
I’ve been using 3.06 a lot for my new project and more, since my first post 18 days ago.
This version seems totally stable! I deliberately haven’t been closing and opening FS to avoid the crashes I got with 3.08.1 (just saving often of course).
I have had literally ONE crash, and that was when I made an index value for a float array go to -1, so that was kind of acceptable. Otherwise it works exactly as I would want, hope and expect. It’s just so much more stable and seems generally to respond faster too.
One thing I noticed is that 3.06 doesn’t install Ruby Snippets (bits of Ruby code for basic stuff) because this was introduced after 3.06. However, if you have a copied and renamed 3.08.1 program installation folder, the Snippets are available in text format, ready to copy and paste into Ruby edit.
I’ve never had a problem loading up many different 3.08.1 schematics, by me and others, so I feel I can now recommend this “downgrade” with some confidence.
Spog
Spog
Spogg - Posts: 3358
O.K.
I'm on board...
Already saved schematics as v308 from v309b!
Loaded this in v306 - et voila it works
Even my Mega project with many deep encapsulated ruby modules are working fine!
Only the ruby sliders needed the well known "After Load Trigger" in the bitmap input.
Thanks tulamide and Spogg for the hint and motivation...
Walter
I'm on board...
Walter
Users browsing this forum: No registered users and 105 guests
