HSV Wrong?
HSV Wrong?
Hi i have been playing around with the colour detection example and the HSV Coords in this example all detect the proper colour but when connecting a colour to HSV module to the detection system it does nor work.
The C2HS module with a colour selector outputs correct HSV Data But the HSV coords inside the example do not corrispond to the correct colours exept yellow! the suggested coords do not fit in with any of the types shown on wikipedia
So is it the detection module thats a bit wierd? What are the other coords for all the standard HSV colours since the correct ones don't work?
Whats going on here?
Cheers Jay
Cheers Jay
- Jay
Re: HSV Wrong?
I see what you mean, the HSV components are correct, but the colour detect uses a different scale.
Apparently the colour detect uses 8bits to define the colour Hue range (ie max 255) but there are 360 degrees in the Hue normally. So to accommodate this the colour detect only uses 0 - 180 degrees instead of 0 - 360. So if you divide the H by 2 you should see some sense. eg. 180 = Red.
- Embedded
Re: HSV Wrong?
Thanks for the reply Embedded. You are a saviour!
i wonder why they did it like that
Best regards
Jay
Best regards
Jay
- Jay
Re: HSV Wrong?
Hi, i just did a mod on the video color detect demo so you can use a color picker and with a HSV map, it's good to see how the color detect module works. i am just assessing the fps, the color interpolations, i dwonder how the color detect makes a 3d array, in hue sat and value, from only 2 colors.
- Copy (2) of Webcam Video player w color detect2.fsm
- (18.19 KiB) Downloaded 1137 times
- datsound
Users browsing this forum: Google [Bot] and 45 guests
