vst exported not working + timing issues
Re: vst exported not working + timing issues
Postby tester » Fri Feb 01, 2013 2:59 pm
I'd appreciate your schematic on that.
p.s.: progress or not - most of what I do in code - I still don't understand ;-)
But my desire to finish the project I work on - is still big.
Would be fun to generate things greater (i.e. with adding randomized frequencies) than this - in DAW render mode, and not in real-time-waiting mode.
tester
Postby trogluddite » Fri Feb 01, 2013 7:03 pm
Hi again,
Here's a very quick schematic showing how to use the automation record for A) discrete value changes (edit box, radio button, toggle etc.) and B) continuous click-and-drag sweeps (e.g. knobs and sliders).
Automation record.fsm
(1.68 KiB) Downloaded 1043 times
NB - works exactly the same in SM.
Postby tester » Fri Feb 01, 2013 10:21 pm
Thanks, will implement it on finish line.
tester
Postby tester » Sat Feb 23, 2013 9:30 pm
You were right with the automation thing.
Which means -- I - just - finished - first - part - of my project! :-)
Pufff... Finally done. Now will be the time for some beta testing.
tester
Previous
