scaled ranges vs acuracy
• Page 2 of 2 • 1, 2
Re: scaled ranges vs acuracy
The key choice here is how important VST automation is to you.
Generally, if I know I don't need automation, I don't bother scaling, and it has not been a problem thus far - and as matti says, it opens up the possibility to create a custom format. If you want nice draggable automation curves, then float 0...1 is the only option using the current VST implementation.
Automation = timeline. So automation is important, because offers changes over time, and thus - I don't need to create timeline within an app. +$100 so to speak. Besides it's too late, everything is now rescaled, and two other projects are re-created from that point.
But I realized something else. Preset/value limits can be higher than automation limits. It will be just the fact, that the value can be automated to some degree (let say, frequency - from 0.00 to 10000.00Hz at rescaling factor x10000), while as itself stored in the preset - can be up-to-whatever (let say 16000Hz, will be 1.6).
Reaper locks values selected for automation in it's own world (and trims them to 0-1 ranges), but does not touches other values.
So the only thing important here is the rescaling factor, which is responsible for accuracy quality (rounding). For frequencies - x10000 at .01 accuracy (x1000 at .001), degrees - x1000 (+/- 360), ratios - x100 at .0001 accuracy (x1000 at .001), percentages x100 or 200 (depending on uni/bidirectionality) and so on.
Yes - I don't know about every music application, but all of the ones I've used (Reaper, Cubase, VSThost), are happy with any value for a non-automated parameter.
trogluddite wrote:The key choice here is how important VST automation is to you.
Actually I'm saying you can have both. You'll just need to do one simple thing: collection of parameter values to a file.
I can post some examples when i have some extra time. Now busy busy
- matti
matti wrote:I can post some examples when i have some extra time.
That would be great - I'm very interested to see what you've done.
The problem that I've had in the past with this is in associating a file with a particular host project - i.e. it works well if the user explicitly loads/saves presets from within the plugin (e.g. store the custom file path to a VST string parameter) - but the if user changes parameters and does not explicitly save the preset, the old values will be loaded when the project is re-opened.
Not a problem for the more organised kind of user, of course; but saving out the presets is one of those things that's so easy to forget to do!
matti wrote:Actually I'm saying you can have both. You'll just need to do one simple thing: collection of parameter values to a file.
The time is crucial, that why I did not decided to digg in that direction. I had a hunch that this could be done that way, but other hunch told me that there would be a lot of work to do, plus - I wasn't certain how it will behave having so many parameters to work with (as I said - c.a. 2000 per project). Usually triggers are the bandits here
So I'm also curious what you have.
trogluddite wrote:matti wrote:I can post some examples when i have some extra time.
No, I'm not doing anything special to the Host side. It should work just fine?
I thought you had problems with the presets that are saved as text files. Surely that is a totally different thing. Is it not?
- matti
Possibly we are just misunderstanding each other. Sure it will all make sense once I can see a schematic - could be I was just trying to do things in a dumb way!
I also have a clearer vison of what can I do when I see schematics.
Users browsing this forum: Google [Bot] and 88 guests
