How to create own R&D components for Flowstone??
Postby keyjslider1 » Tue Jul 03, 2018 11:38 pm
I need urgently a LOOP primitive for green with "while/until" conditional logic (looping stops if condition meets).
All experiments with various schematics, incl. the Ruby-based one failed... I put some posts about this module, also into Flowstoner wishlist...
The only way I see is to create the one by myself.
Has anybody had experience with this? Is there any developer construction kit for Flowstone? Probably, may I derive access to existing module files for editing?
Some hints??
keyjslider1
Re: How to create own R&D components for Flowstone??
Postby ChrisHooker » Wed Jul 04, 2018 3:19 am
Hey slider,
Are you looking for a looped counter?
Does the attached schematic work for your needs?
I have 2 counters in this schematic:
- One is green (connected to the conditional), which is currently set to run at Tick25.
- The other is a blue counter (runs at sample rate) that I've previously created and just threw in there for you. (Use the "TotalCounter" output.) It should be easy enough to connect a conditional to the boolean "RUN" control of this one, in the same manner as the green.
Looping Counters.fsm
(5.88 KiB) Downloaded 885 times
ChrisHooker
Postby tulamide » Wed Jul 04, 2018 5:20 am
Also, why is it so difficult for people to accept, that their concept is wrong and not Ruby? I already said it in the other thread, you have to adapt to event-driven code (and Flowstone's implementation of Ruby). Or else you will fail each time you try to use Ruby.
conditional_counter.fsm
(696 Bytes) Downloaded 849 times
cron
