Triggering switches with Midi notes.
Re: Triggering switches with Midi notes.
Postby lalalandsynth » Sat Sep 29, 2018 6:27 pm
You can observe the behaviour in this schem by using the PC keyboard as input using R(65) and U(71) and seeing how they interact , most notably they will not play at the same time and when playing one note and then another it will start the release phase of the first one.
I am going to try some other envelope and see if that makes a difference.
64 bit alpha
Midi Trigger mixer_edit_5_7.fsm
(341.69 KiB) Downloaded 927 times
lalalandsynth
Postby martinvicanek » Sat Sep 29, 2018 9:24 pm
Sorry I can't open the last schematic, tried with 3.0.8.1 and 3.0.9beta2.
DON'T USE THE BETAS THEY ARE INCOMPATIBLE.
READ THIS:
viewtopic.php?f=2&t=11635&p=45138&hilit=betas#p45138
If you have created your schematic with a beta, indicate it loud and clear so people don't have to click away dozens of annoying notifications.
Please! :evil:
Regarding your concept: cosider that the selector prim recompiles your code ans interrupts the audio stream each time you switch. Maybe you can achieve what you want in another way?.
Flowstone's voice management is tricky but efficient. Try not to mess with it unless there is a compelling reason to do so. Be prepared for a deep dive.
Postby lalalandsynth » Sun Sep 30, 2018 1:38 am
I am using the 64 bit alpha and I did mention it....in one of the posts , I will fix it in the others. sry mate.
To explain what I want to do :
I want to control 12 ADSR´s with MIDI notes , each one passing an external/routed audio stream in Reaper.
In reaper you can route as many tracks into a channel as you want.
So I want to set up 12 channels , all routed into one track and then a midi track will control via an adsr which one of those tracks plays through the one master track.
I can do this to a certain extent , that is , it works in monophonic mode but as soon as i start playing more then one adsr it gets wonky.
lalalandsynth
Postby martinvicanek » Sun Sep 30, 2018 4:13 am
Earlier in the thread the "Note Equal" prim was mentioned. Not sure how the timing of that is.
Here is a little demo that switches at samplerate. Needs optimizing, I know. Is it helpful for your purpose at all?
MIDIContrloledRouting.fsm
(51.75 KiB) Downloaded 890 times
Postby lalalandsynth » Sun Sep 30, 2018 9:08 am
This is excellent ! THanks.
I guess I neglected to mention that all tracks are meant to be stereo :P
I modified it a bit to handle that.
Seeing that there are no adsrs I might need a declicker as I will be switching a lot of bass:)
Also, it does not work in 64 bit alpha , the ruby script give me an error inside module?
Do you not have the alpha yet ?
lalalandsynth
Postby lalalandsynth » Sun Sep 30, 2018 9:11 am
It seems to be ok if I delete some the notes ?
error 2.jpg (119.07 KiB) Viewed 14925 times
lalalandsynth
Postby lalalandsynth » Sun Sep 30, 2018 9:34 am
Having said that , this is such a simple and incredibly creative thing to play with.
lalalandsynth
Postby lalalandsynth » Sun Sep 30, 2018 11:58 am
I just wrote the code back into the ruby window and now it works.
lalalandsynth
Postby lalalandsynth » Sun Sep 30, 2018 1:58 pm
As a matter of interest it might be cool to add the ADSR´s but this is absolutely brilliant as it is.
I guess if you wanted to start switching pads or more ambient material the ADSRs would be needed.
EDIT: As I start to use this , yes , optional ADSR , switched in on the desired channels would be perfect , can it be done ?
Thanks Martin !
lalalandsynth
Postby martinvicanek » Sun Sep 30, 2018 4:39 pm
Yes, it can be done.
(Did I mention I have a donation button on my website? :mrgreen:
https://vicanek.de/donate.htm)
+ ADSR
(61.77 KiB) Downloaded 879 times
