Gate to Amp. How do i do that?
• Page 2 of 4 • 1, 2, 3, 4
Re: Gate to Amp. How do i do that?
Maybe check this thread.
viewtopic.php?f=2&t=13380
lalalandsynth - Posts: 600
martinvicanek wrote:Halon wrote:A lot of synthesizers have the option to switch from Envelope to Gate for the Amplifier, so you might use the envelope for other tasks (modulation).
You can keep the amp envelope and use another envelope for other tasks, no?
Yes but I would like to simulate a classic monophonic 1 envelope synthesizer.
lalalandsynth wrote:Maybe check this thread.
Will have a look thanks.
Spogg wrote:The MIDI to Voice and Voice to Poly prims open a channel when a note is pressed. While the channel is open (a note is sounding) you can switch on and off any signal you wish.
You must have a minimum of one envelope prim in the poly system. The prim tells the software when to close a poly channel.
When note-off happens the envelope prim has to be told to close the channel, otherwise each new channel opened will never be turned off and the CPU will rocket.
If that’s not clear I could maybe make a demo...
You have helped me a lot so il afraid to ask
- Halon
Is this what we're after?->
Hope helps!
Hope helps!
nix - Posts: 817
That's the kind of thing I had in mind Nix!
cool
IMO-It would work prolly without any envelope at all,
and just the gate to turn it on and off-
if u meant to intonate it mightn't Spogg mate
addendum--I thought it best to test. It's OK to use the gate and have no envelope in the schematic
nix - Posts: 817
nix wrote:
... It's OK to use the gate and have no envelope in the schematic
Hmmm... Seems I was wrong then.
Something to learn every day with FlowStone!
Thanks Nix, but for some reason i cant open your schematic.
This is true with other schematics I have downloaded feom you.
- Halon
darn mate-
this is for FS 3081,
it really should open in it.
Here are images->
^this one doesn't use gate
^this one multiplies by gate
hope helps
Here are images->
hope helps
nix - Posts: 817
I have the FL Studio version of SynthMaker/Flowstone. But thank you for the images.
- Halon
No worries!
I'll keep your version in mind.
I'm only running Fruity 7 and 20 atm,
but maybe Image_Line will like the 64 bit version on FS-
and we can try to popularize it more
nix - Posts: 817
