Bitmap Button ?
Bitmap Button ?
Good evening everyone !
For a project I would like to create a bitmap based button that responds to three states :
1. Normal;
2. Mouse Over;
3. Pressed.
I tried to tinker with the "Button" prefab by inserting a single "Bitmap" and removing the "Background" and "Label" part of the Ruby code. But apart from that, i'm stuck.
Indices or tracks to follow ?
Thanks in advance (and sorry for my bad English, I'm French).
1. Normal;
2. Mouse Over;
3. Pressed.
- az-terisk
Re: Bitmap Button ?
az-terisk wrote:Good evening everyone !![]()
1. Normal;
2. Mouse Over;
3. Pressed.
Not sure if this is what you require:
Bitmap Button (Dual).fsm- (15.24 KiB) Downloaded 1016 times
tiffy - Posts: 400
Re: Bitmap Button ?
Hello Tiffy and thank you for providing this schematic.
Now, if I may dare: Is it possible to set up things in a way
that the button colour changes in its three states?
Example: up=red.jpg
If you found the time to answer that, I'd really appreciate it.
Thank you.
Regards
Phil
Example: up=red.jpg
Thank you.
Regards
Phil
Phil Thalasso - Posts: 150
Re: Bitmap Button ?
Phil Thalasso wrote:Hello Tiffy and thank you for providing this schematic.
Example: up=red.jpg
Thank you.
Regards
Phil
Yes, it is possible (and very easy too) to change the schematic in order that the Button Color changes for instance when Mouse-Over is activated as you mentioned "Blue" and "Red" for Mouse-Up and "Black" for Mouse-Down. I previously done something similar but I will have to search through my examples when I have time and upload it (unless someone else is quicker than me and would be so kind to upload an example here) ...as I am currently working on something else. Do you want to use Bitmaps for the Colors?
tiffy - Posts: 400
Re: Bitmap Button ?
Thank you Tiffy for the quick response.
"Do you want to use Bitmaps for the Colors?"
Yes, very much so. I like things to look
appealing (I know ...
Regards
Phil
Regards
Phil
Re: Bitmap Button ?
Hi Phil and az-terisk,
To get the bitmap to change while hovering, you just need to route the hover status to the selector for the bitmap.
Since status is On/Off, you must convert the On State to an Int (either by forcing a connection to a Float-based prim (CTRL+SHIFT while connecting), or by using a "Select" prim that takes one of 2 inputs based on a Bool status), and then make that Int value (when hovered) high enough that when added to the Bitmap Selector index, it changes to a new bitmap to indicate hovering. More complicated to explain than to do.
Attached is a schematic.
Since when hovering over the button, all it shows is the hover bitmap, you can't tell when clicking what state you're changing it to, you can also add a multiplier (by zero) to effectively turn off the hover-state when a click trigger is sent. A delayed trigger will reset back to enabling the hover state bitmap.
Attached is a 2nd schematic to illustrate.
I've modded Tiffy's schematic for these - please note that these are not set up for preset handling nor automation.
- ChrisHooker
Re: Bitmap Button ?
Thank you, Chris, well done...I like it.
Hope it is what the other two gentlemen require.
tiffy - Posts: 400
Re: Bitmap Button ?
Wonderful!
Thank you Chris and thank you bunches. During my last vacation I was trying to get at what you presented in minutes - obviously to no avail.
I have to frankly admit that I would not have been capable of thinking-up anything alike myself.
Great learning experience!!
Regards
Phil
Regards
Phil
Re: Bitmap Button ?
Thanks, I find these ideas useful. It's funny how they're simple to do in theory but the other day I ruined a schematic trying to add mouseover's lol.
Re: Bitmap Button ?
Good evening,
First, sorry for the late response. A big thank you to you, that's exactly what I was looking for !
I'm going to study this schematic.
Good evening !
Good evening !
- az-terisk
