How to remove empty items
I'm building a semi modular effect. The user can select an effect on every slot, but when an effect is chosen, then in the other effect slot must the effect removed. I'd build some logic, but I have empty places. How can I remove them?
See my schematic
See my schematic
Yuroun - Posts: 27
Re: How to remove empty items
I found some ruby code online. Seems to work. Try out the attached module.
SelectFX2.fsm- (2.37 KiB) Downloaded 1148 times
- briant1972
Hi Yuroun
I would do it like below, all one line and no extra bits required
output @SourceString.gsub(@OldPattern,@NewPattern).each_line.reject{|x| x.strip == ""}.join
Best Regards
Best Regards
- Jay
Thanks Guys. Both are elegant solutions. I prefer the version of Jay. He modified my Ruby code nicest
Yuroun - Posts: 27
Why thank you Yuroun!
glad it is of use for you m8
Best regards
Best regards
- Jay
Jay wrote:Why thank you Yuroun!
Because it's a normal thing to do, If you get some help.
For me it is
Yuroun - Posts: 27
It's a mannerism in English Yuroun 8D
Or was that a good for a pun?
hehe
hehe
nix - Posts: 817
nix wrote:It's a mannerism in English Yuroun 8D
hehe
Lol
Yuroun - Posts: 27
Here's the version I had in mind. It's not working perfectly
Yuroun - Posts: 27
yeh its just a saying Yuroun
a bit like "well thank you very much"
I see what you mean about not working perfectly, it seems the last column does not always update properly, I will have a look at it and see what i can come up with
Best Regards
Best Regards
- Jay
