Ruby trigger basics
Ruby trigger basics
Postby gvalletto » Tue Mar 12, 2019 3:07 pm
Hi all. I want to improve the time precision of a complex step modulator made with DSP code and green prims.
Does anybody know how to make Ruby codes to replace these green trigger prims?
gvalletto
Re: Ruby trigger basics
Postby gvalletto » Tue Mar 12, 2019 7:15 pm
...at least tell me where to find that to learn to make it myself... :)
gvalletto
Postby tulamide » Tue Mar 12, 2019 8:19 pm
Here you are. However, it doesn't make sense, since you convert from green to Ruby, then back to green. The unreliable timing of green stays. And the overhead will probably make it more CPU intensive.
bool-trigger.fsm
(785 Bytes) Downloaded 864 times
Postby gvalletto » Tue Mar 12, 2019 8:44 pm
Thanks Tulamide! I understand the reason why it has no sense if I use them in an isolated way (that´s, a Ruby module with just that small code). Perhaps if I add that code in several already existent Ruby modules on my scheme, so to avoid go and back to green, it may make the difference... I will try.
gvalletto
Postby RJHollins » Tue Mar 12, 2019 10:02 pm
Thanks Tulamide!
Postby RJHollins » Wed Mar 13, 2019 10:40 am
Appreciate the RUBY offer ... but I could not load in the schematic [v:3.06]
Postby gvalletto » Wed Mar 13, 2019 7:42 pm
RJHollins wrote:Appreciate the RUBY offer ... but I could not load in the schematic [v:3.06]
Search for the topic "Ruby basic examples". There I put the scheme fixed.
viewtopic.php?f=2&t=15205&p=48563&hilit=Ruby+basic+examples#p48563
gvalletto
Postby gvalletto » Fri Mar 15, 2019 12:35 pm
tulamide wrote:Here you are. However, it doesn't make sense, since you convert from green to Ruby, then back to green. The unreliable timing of green stays. And the overhead will probably make it more CPU intensive.
Hi Tulamide. I deleted some of the code of your trigger scheme, and surprise, it still working... what can be the difference? Here I attach the original and the modified version.
ruby trigger FS3081.fsm
(1.77 KiB) Downloaded 845 times
gvalletto
Postby tulamide » Fri Mar 15, 2019 5:30 pm
When only having a line of code (or several) that will be executed whenever the RubyEdit gets triggered, you can omit the event method definition. I wouldn't advise it though. Read chapter 8 of the user guide, it is a treasure for questions like these!
Postby gvalletto » Fri Mar 15, 2019 6:59 pm
Thanks! II read it several times, but I'll read it again ...
gvalletto
cron
