Data extraction problem
I never been able to extract data using the watch method.
I need to send the value that is being watched to the green out.
Note:
i have tried many different things for the line
output 0,"1.size",v.size
output 0, watch
output 0,"1. value"
output 0, wake the hell up!!!!
Just can't get it
Note:
output 0, watch
output 0,"1. value"
Just can't get it
Re: Data extraction problem
MyCo wrote: output 0,v.size
Was sure i tried that first time. So i went off trying other stuff.
That's why in the end I just didn't get it.
I could see it's already declared, values already present in the output window
so WTF is going on....
All good. Cheers.
where can i find this ppq prim with the float output? is it in FL ?
Nubeat7 - Posts: 1347
Nubeat7 wrote:where can i find this ppq prim with the float output?
Ha ha, dream on!!
That's what I was doing with this circuit. Trying to replicate the FL Clock exactly,
by using a free running ppq signal.
I made the PPQ circuit hoping to jump the last hurdle, but failed.
viewtopic.php?f=2&t=1360&start=40#p5139
See you back at VST timing thread
