Simple Midi Display
Simple Midi Display
Hi to all
Can i export this simple schematic only as midi instrument and load it in Ableton live 9 as midi effect ?
Thanks! for the help
Midi Display.fsm- Midi Display
- (34.94 KiB) Downloaded 965 times
ChrisPap - Posts: 20
Re: Simple Midi Display
ChrisPap wrote:Hi to all
*looks over file
Hmm, outputting midi information by using a standard keyboard. It's a good idea. This is more of an interpreter. I'm sorry - It's not My area of expertise.
Martin Vicanek would know I think.
BTW, great idea; I like it. It's like voices without the effect on a midi interpretor. Something like it should be in every synth! Spot on.
I use it a lot of time with my modular G2 from clavia ,but now want to use it and with Ableton live 9 x32bit as a midi instrument to see midi value from controllers .I would really appreciate it if Martin Vicanek help me or someone else can help with this .Thanks again wlangfor
would it be OK to use it as a VST/VSTi?
I don't know about MIDI effect specs at all
nix - Posts: 817
Hi again ! . If make it export as vsti ,when open it in track or channel in some Daw or in Ableton and then load some other really Vsti ,the midi display replacing from the new vsti as normal procedure in all Daw .Now Vst is not possible to make it because is midi instrument and not effect and its problem .The vsti produce audio ,the vst processing audio and the midi effect, processing or modify the midi data or view the data as in this simple display. The only way is one. Someone from here in god mode
in midi, need to help us ,or this app need to update
and add and midi export, but this update look fantastic dream to me as and x64bit dream ver .
