Midi Player
Re: Midi Player
Postby MyCo » Mon Apr 29, 2013 11:42 pm
Update
- Added Play position tracking outputs
- Added Event combining for events that are very close each other
- Improved Midi filters, now they track active notes
- Some rearrangement in the player code
Download is in the first post
MyCo
Re: Midi Player
Postby Jay » Tue Apr 30, 2013 3:47 pm
Hi Myco and all
How would one extract a GM patch number from a track from within a midi file? Is that possible with this player?
Best regards
Jay
Re: Midi Player
Postby MyCo » Tue Apr 30, 2013 4:42 pm
Jay wrote:How would one extract a GM patch number from a track from within a midi file? Is that possible with this player
The player should playback "Program Change" events, you should just wait for a channel message with the status: 192 the patch nr. is in the first data byte.
Program change events only have 1 Data Byte, but the FS-Midi requires 2 data bytes... don't know if this works with other devices.
MyCo
Re: Midi Player
Postby Jay » Wed May 01, 2013 11:46 pm
ah thanks myco for that answer! i was going to attempt to club together a GM unit using the SFZ system and some GM banks i have! will give it a go! will be fun to try it :)
Cheers!
Jay
Previous
Users browsing this forum: No registered users and 148 guests
