Martin - pick a GUI for Karplus synth?
Re: Martin - pick a GUI for Karplus synth?
Postby k brown » Mon May 20, 2019 10:31 am
Well after a bit more mucking and head-scratching I got partway there technically - figured out how to bypass the KS internal noise source and connect the synth's osc and/or noise. But yeah, even with Martin's correlations above, I can't figure out which controls I can eliminate and still have it function somewhat as described (sketchily) in the Accelerator manual. Panel real estate is limited and Martin's build has several controls not on the Accelerator. Also the Acc. String Filter has three mod inputs: Tune, Feedback and Damp, Martin's K-S has no mod inputs and I can't quite work out how/where they'd be added.
I can buy some real estate buy ditching the EQ - better to have the K-S; then I can just include all Martin's controls; if I can just figure out the three modulation inputs.
Postby Spogg » Mon May 20, 2019 10:52 am
k brown wrote:I can buy some real estate buy ditching the EQ - better to have the K-S; then I can just include all Martin's controls; if I can just figure out the three modulation inputs.
Yeah that sounds better! I've never been a great fan of having eq on a synth. You can do that easily in the DAW.
I expect someone will put me right on that view! :lol:
BTW, I didn't see a preset manager in the synth. Maybe it was hidden away somewhere...
Postby k brown » Mon May 20, 2019 11:03 am
Yes all the versions I've saved have one - the first one I posted, it's probably hidden behind a panel GUI.
To bed now - 3am here.
Postby lalalandsynth » Mon May 20, 2019 11:28 am
I second that , no need for eq on a synth.
lalalandsynth
Postby k brown » Mon May 20, 2019 5:20 pm
Yep.
I do think I'll do two versions of this, because I do Like the sound of the 'country boy's' comb filter.
Do I need to worry about this inside the K-S IV?
1pole HiCut.jpg (129.19 KiB) Viewed 18902 times
Was this module superseded?
Postby k brown » Tue May 21, 2019 7:06 pm
I fixed this by toggling the Ruby inside the 'error alert' module off, then on.
Postby k brown » Tue May 21, 2019 8:05 pm
@Martin -
The 'randomOsc4' synth is truly beautiful. Eagerly awaiting further development. :P
Postby martinvicanek » Wed May 22, 2019 3:43 am
k brown wrote:Martin - have you had a chance to look at my website to see if there's a GUI style (or combination thereof) you'd like for KS IV?
So much to choose from, your site is overwhelming. twoBYthree is cool!
Postby k brown » Tue Jun 04, 2019 9:21 pm
Two By Three's GUI is based on a commercial plug-in (Ableton Operator), so best to stay away from that. Since you seemed pleased with the GUI for RandomOsc 4, here's K-S IV (with Spogg's additions and presets) in that style.
K-S IV_s copy.jpg (26.68 KiB) Viewed 18614 times
K-S IV_s.fsm
(220.78 KiB) Downloaded 1006 times
And a 'lite' version with just the Karplus, stripped of the effects.
K-S IV.fsm
(155.35 KiB) Downloaded 999 times
With FS 3.0.8.1
Postby wlangfor@uoguelph.ca » Wed Jun 05, 2019 12:48 am
lalalandsynth wrote:I second that , no need for eq on a synth.
Maybe You're right but I often rely on them.. :(
Downloaded Your Synth BTW Kevin, thanks :D
My youtube channel: DSPplug
