Latest update for Martin's 'Randy' synth
Re: Latest update for Martin's 'Randy' synth
Postby k brown » Wed Jul 03, 2019 1:16 pm
And here's Randy + with the Noise EG :
Randy +_k.fsm
(607.03 KiB) Downloaded 1059 times
Randy +_k copy.jpg (172.44 KiB) Viewed 20047 times
Postby Julian Ray » Wed Jul 03, 2019 10:05 pm
Thanks a lot, Kevin!
I'm going to make some nice presets now.
Julian Ray
Postby k brown » Thu Jul 04, 2019 8:59 am
Here's Randy + with the Noise EG and a dedicated Modulation Envelope:
Randy +_k3.fsm
(639.48 KiB) Downloaded 1025 times
Randy +_k2 copy.jpg (179 KiB) Viewed 19834 times
Postby trogluddite » Thu Jul 04, 2019 9:58 am
And all my presets included and working, too - very nice! :D
Postby Julian Ray » Thu Jul 04, 2019 3:09 pm
Great !
Julian Ray
Postby Julian Ray » Thu Jul 04, 2019 5:31 pm
As Noise has it's own filter, it might be useful sometimes for noise to bypass the main filter.
Like a switch in the Noise section.
What do you think guys?
Julian Ray
Postby k brown » Thu Jul 04, 2019 7:15 pm
Yeah, I'd like to hear Martin's thoughts on the Noise routing. It goes through hell on it's way to the output :shock: ;) - first it's own comb filter, then the main Filter and finally the Spectral Tilt filter, which the way Martin did the original GUI layout would lead one to think is only affecting the oscillator/s.
Postby Julian Ray » Thu Jul 04, 2019 9:05 pm
Of course!
By the way... I've noticed that Tilt knob has max signal level around 0.5 and the level greatly drops close to 0 or 1.
Just theoretically, is it possible to compensate, so that level will keep the same through the whole Tilt knob rotation diapason?
There are some good sounds out there :D
Julian Ray
Postby k brown » Fri Jul 05, 2019 12:43 am
I had other thoughts about this, such as providing the option of bypassing the EG (as in the original), shaping by the VCA EG instead, re-routing the Noise through the Comb Filter only, the main Filter only, bypassing the Spectral Tilt, etc., but any further tinkering would have to be done by Martin. 8-)
Postby Julian Ray » Fri Jul 05, 2019 12:49 am
trogluddite wrote:
k brown wrote:but not being very 'norm' myself
If you do see any "normal" people showing up on the forums, you should immediately report this to a moderator - we can't be having that kind of behaviour going on around here! :lol:
:lol: 10/10! I really wish there will be LIKE button here, on forum :D
Julian Ray
