arraybuilder & triggerswitch issue
hi there, i found some strangething using trigger switch with arraybuilder, the array builder gets values from triggerswitch when second in of the trigger switch is false (there should be no signal possible) watch the schematic, if you put a sample and hold in between it works correctly... a bug?
arraybuilder_and_triggerswitch.fsm- (1.45 KiB) Downloaded 912 times
Nubeat7 - Posts: 1347
Re: arraybuilder & triggerswitch issue
I think the answer is in this example
Summary example of trig system
Last edited by digitalwhitebyte on Fri Jun 21, 2013 1:08 am, edited 1 time in total.
digitalwhitebyte - Posts: 106
As DWB noticed, it's the behaviour of the trigger system. It not only happens with arraybuilder (see attached file). When there is a trigger coming into the right input box, it asks the trigger blockers for their current value. All of the trigger blockers then ask the "value" input box. So the trigger blockers all get the same value and pass it to the right input box.
trigger blocker.fsm- (383 Bytes) Downloaded 905 times
MyCo - Posts: 718
thanks for the replies, ok in blocking mode it works exactly like the triggerblocker! hmm, like its description says
so should be more careful using it, but good to know that reverse triggers can be "blocked" with a sample and hold.. damn and i was shure i understood trogs trigger tutorial... now i do understand it more!
