Lfo in ruby
Lfo in ruby
Hello, trying to write the LFO on Ruby, but it is not my true test, I think. I need a number generator for example from 0 to 1 and back again, what I want step , endlessly. Data format float for example, an example is attached ...
Do not get me to do the cycle, may be who knows how to do this?
Okey... screenshot.
http://rghost.ru/46940249/image.png
Okey... screenshot.
- borodadada
Re: Lfo in ruby
missing an important parameter
which increase-rate should reach?
seconds, milliseconds or more?
- Tronic
Re: Lfo in ruby
sorry, I find it difficult to translate this answer
- borodadada
Re: Lfo in ruby
why not putting the values in an array and increase the index with time - is this possible? (i`m not at home atm..)
Nubeat7 - Posts: 1347
Re: Lfo in ruby
arr = [1, 2, 3, 4, 5, 6,.....] ?
arr[0]
arr[1]
arr[2]
arr[0]
arr[1]
arr[2]
- borodadada
Re: Lfo in ruby
i tought a while loop .. which runs as long as input x is on
Re: Lfo in ruby
something like:
but don`t know if the syntax for the time adding works like this (still not at home)
i = 0
values = [your values]
while @inX #or what ever condition
output values[i],t+2.2
i += 1
Re: Lfo in ruby
If I'm not mistaken, this ruby can not use loops.
- borodadada
Re: Lfo in ruby
What you want is a Ruby wavetable osc maybe,
and sure u can use feedback loops in Ruby.
I can help in the next week
nix - Posts: 817
Re: Lfo in ruby
borodadada wrote:sorry, I find it difficult to translate this answer
your ruby LFO needs to work with the audio or just for the greens?
at what speed must run the increase of the step for your counter?
- Tronic
