Lfo in ruby
• Page 2 of 2 • 1, 2
Re: Lfo in ruby
No stream, Green circle f
float. Basic speed static.
demo version ^)
http://rghost.ru/46944750/image.png
demo version ^)
- borodadada
Re: Lfo in ruby
thru_array.fsm- (427 Bytes) Downloaded 888 times
Nubeat7 - Posts: 1347
Re: Lfo in ruby
fantastic, thank you
but how change time ? ^)
speed = 0.1 not work :S
- borodadada
Re: Lfo in ruby
itsbecause time % size is the index for the array and this counts only the full numbers - with a speed of 0.1 it is counting 1,1.. 1.2... 1.3... and so on so it counts every 10 steps... just multiply the time with 10 before you do the modulo... or 100 when speed is hundreth...
Re: Lfo in ruby
def event i,v,t
v=*(1..1000)
a=*(2..999)
a.reverse!
va = v+a
size = 1998 #arraysize
speed = 0.0101
c = time * 1000
if @on
output 0, va[c%size]
input 100, nil, t + speed
Okey.... modify, work.
Thanks!
v=*(1..1000)
a=*(2..999)
a.reverse!
va = v+a
speed = 0.0101
c = time * 1000
if @on
Thanks!
- borodadada
