Stream FFT and iFFT
Re: Stream FFT and iFFT
@MyCo
I updated the code(same post), it was wrong, now working,
but the approximation seems to be not good, still too high,
in the meantime I'm trying other solutions.
digitalwhitebyte - Posts: 106
// Range of x [0,1]
// The maximum error is about 8*10^(-10).
x = @ins[0].to_f
y = 2*x-1
atan = 0.0318159928972*y+0.950551425796+3.86835495723/(y+8.05475522951+
39.4241153441/(y-2.08140771798-0.277672591210/(y-8.27402153865+
95.3157060344/(y+10.5910515515))))
output 0, atan
Sounds great, except for the 4 division in the main code.
Now I try to take it in ASM, and we shall see what is suitable for the cpu.
DWB, in your last post you can rearrange the expression so you get only one division of two polynomials. May or may not be faster.
awesome what you`re doing here guys! i`m a bloody beginner in this area but you really motivate me to read and try to understand all this fourier transforming,
to bring a little part too i optimized mycos window options, maybe here and there it could be done better but most of the stuff should be optimized fine
window optionsopt.fsm- (13.71 KiB) Downloaded 1776 times
Nubeat7 - Posts: 1347
martinvicanek wrote:DWB, in your last post you can rearrange the expression so you get only one division of two polynomials. May or may not be faster.
here is where we see your skill.
hehe, a little help?
DWBs new atan code is really good. In the 0..1 range I can't measure any error. Outside of that it's not very exact. But maybe we can use trig. identities to flip any input into the 0..1 input range. This should get us very close to a real atan.
@Nubeat: Thanks for your work. I know that this wasn't any fun, that's why I avoided that.
MyCo - Posts: 718
here is the simplified version for DWBs atan:
maybe there is a little room for further optimization
def atan(x)
ax = x.abs
num = 1.93417747861 * (ax**3 - 1.3821888526*ax**2 + 1.2783790120*ax - 2.785730712)
denum = ax**4 + 2.1451887622*ax**3 + 6.258905830*ax**2 + 3.285923272*ax + 5.86468903
linear = 0.0636319857944*ax + 0.918735432899
res = linear + num / denum
res = -res if (x<0)
return res
if (@x.abs>1)
output(0, ((@x>0) ? 1 : -1)*Math::PI*0.5 - atan(1.0/@x))
else
output(0, atan(@x))
MyCo - Posts: 718
OK, here is the current setup. I converted everything that I've found into code. DWBs new one is also in there. I've used the trig. identities to make it work full range. The results from this one are the best, although it's not the fastest.
So, any ideas to optimize the code of it? Maybe there are chances to minimize the error, just by rearranging. The Ruby version doesn't have that much error, as the code version. This comes from rounding (Ruby uses double precision), so maybe this rounding error can be reduced.
atan and atan2 compared v2 (MyCo).fsm- (20.56 KiB) Downloaded 1804 times
MyCo - Posts: 718
// Range [0,1] |error| ~ 3.2e-7
streamin x;
streamout arctan;
float num,denum;
num = 0.05030176425872175099 *
(-6.9888366207752135 + x) *
(3.14559995508649281e-7 + x) *
(2.84446368839622429 +
0.826399783297673451 *
x + x*x);
denum = (1 + 0.1471039133652469065841349249 * x +
0.644464067689154755092299698 * x*x);
arctan = num / denum * -1;
maybe this seems to be a good compromise between accuracy and speed.
I've done all the conversion stuff (and code optimization) already for your other version. The error is very low, and I've added it to the stream FFT project... where I measure the error of forward and inverse conversion. The max. error there is 88dB so far.
I've attached to current status. The atan2 code is in the "To phase" module, and isn't converted into assembler right now. To test the whole thing, you have to load in a Wave or MP3 into the stream player.
Stream FFT v7 (trogluddite, MyCo).fsm- (262.64 KiB) Downloaded 1861 times
MyCo - Posts: 718
