Pololu GPS Module
A wide range of example files that you can load up in FlowStone
Pololu GPS Module
Postby admin » Sun Jun 19, 2011 4:50 pm
Here is an example of the LS20031 GPS module from Pololu working with FlowStone.
This is a TTL based (3.3v) serial device and outputs various GPS co-ordinates, Longitude, Latitude, Altitude, Speed on ground, Time and Date etc.
The product can be found here: http://www.pololu.com/catalog/product/1249
Pololu GPS Module.jpg (12.34 KiB) Viewed 69584 times
You will also need their USB to TTL comport adapter (for 3.3v TTL)!
http://www.pololu.com/catalog/product/391
We have also added a button that loads Google Maps at the correct GPS location!
LS20031 GPS Module V3.fsm
(8.47 KiB) Downloaded 4469 times
admin
Site Admin
Return to FlowStone Examples
