help me solo problem
hello flow man
a little help for my solo button. after having to spend much time on the problem, I m gives to the community. a big thank you for your support. the bug is in the OSM. thank you
solo problem grrrrr.fsm- (6.05 KiB) Downloaded 874 times
- mimine
Re: help me solo problem
Your problem description doesn't offer many details... so I don't know if you really wanted the result in the attached schematic.
solo problem (MyCo).fsm- (5.22 KiB) Downloaded 867 times
MyCo - Posts: 718
yes that's exactly what I wanted to do. even with too little explanation, you sue respond quickly and with a perfect job. thank you for your presence. myco very productive. I will work for your method of reflection to improve mine. good job
- mimine
