Sine in ruby, output float.
Postby borodadada » Thu Aug 08, 2013 7:25 pm
Friends, how to output values ​​in float format
http://rghost.ru/47986531.view <<<--- Picture
borodadada
Re: Sine in ruby, output float.
Postby MyCo » Thu Aug 08, 2013 7:43 pm
it really depends on "what value do you want to get from the stream?"
Frame to float.fsm
(6.39 KiB) Downloaded 1062 times
MyCo
Postby borodadada » Thu Aug 08, 2013 7:57 pm
Need real-time, Complex number, real numbers and imaginary unit.
borodadada
Postby MyCo » Thu Aug 08, 2013 8:11 pm
Don't understand what you mean. Stream data has no imaginary parts.
MyCo
Postby tester » Thu Aug 08, 2013 10:19 pm
I guess it's about converted values into complex numbers. We had a lot of it on electronics looong time ago. Calculations made on complex numbers (a+ ib) refered to AC signals. @borodadada - better describe what you would like to get with it.
tester
Postby borodadada » Fri Aug 09, 2013 5:37 pm
guys, I can use any option, the amplitude values ​​in real time, as in the picture I uploaded, need output with Ruby, in a numbers format.
borodadada
Postby borodadada » Sat Aug 10, 2013 8:46 am
white noise...............
borodadada
Postby borodadada » Sat Aug 10, 2013 9:30 am
ohh... done
code not working... because sound card is not active, DS OUT
def event i,v
a = v.to_array
output(a)
for some reason, flowstone die.....
borodadada
Postby (_zb_) » Sat Aug 10, 2013 10:06 am
MyCo, tester
Thank you very much. We began to teach programming a week ago, We began to teach the sound of 10 years ago. and very frustrating when such simple topics so hard to understand
(_zb_)
