Networking & FS
Networking & FS
Postby Drnkhobo » Sat Oct 06, 2012 11:12 pm
Im trying to get FS's client & server modules to work.
Now ive got the server running, when i try to connect with client, it wont connect.
Ive enabled FWall access for FS so im stumped. Nothing in the forums either. . . .
I know its probably a basic answer but I have to start at the beginning.
Here is my schematic if anyone wants to take a look. . .
Network Tests.fsm
(441 Bytes) Downloaded 1136 times
Drnkhobo
Re: Networking & FS
Postby support » Sun Oct 07, 2012 10:44 am
Here's a working example that sends data to and from the same PC to test the networking.
1) Start the Server
2) Open the Client
3) Send data from Server
New Network Test.fsm
(428 Bytes) Downloaded 1231 times
support
Re: Networking & FS
Postby Drnkhobo » Sun Oct 07, 2012 3:46 pm
Thanks support, quick reply esp for a sunday :shock: :D
Ive tried your schematic but it still wont connect :?
The log says:
'Trying to connect...
Could not connect to server'
Why is it not connecting?
Just got a "Virtual call' error in FS and it quit????
I dont get it,
IP - correct
Port - correct
The server log displays the server running on said port and IP. But no connection. . . .
Drnkhobo
Re: Networking & FS
Postby support » Mon Oct 08, 2012 10:23 am
If it can't connect then the port could be blocked or being used by something else?
Try some different port numbers (eg. 1000), this works here but you may have to open the port in your router.
Does the Server start ok (must be started first)?
Here's what it looks like here :
New Network Test clip.png (143.95 KiB) Viewed 26875 times
support
Re: Networking & FS
Postby Drnkhobo » Mon Oct 08, 2012 12:34 pm
Yeah, double checked last night if I got everything correct, IP/PORT ect. Router settings. But still nothing.
Turn on the pc this morn, load up my schematic again and it works!???????
Wtf?
I changed NOTHING. Anyway it's working now. Thanks :)
Is it only string data I can pass through?
I'm asking because I'm looking to send digitalised analog video streams over Ethernet.
So:
Analog camera module attached to flow board - flow board's MPU digitalises signal & sends via Ethernet . . .
Would I be able to encode the video stream in FS? - I'm thinking its done in ruby accessing ffmpeg dll functions???
Drnkhobo
Re: Networking & FS
Postby support » Tue Oct 09, 2012 6:50 pm
Great!
Sometime rebooting resolves IP conflicts.
For streaming video you could try it, there is a HEX mode for sending raw data.
We did play with the VLC video streaming by making a FS module but it was a bit unreliable (VLC that is).
support
Re: Networking & FS
Postby qqwy » Wed Dec 12, 2012 10:04 am
I know, this topic has been inactive for a while, but my issue is fully related to this topic.
I tried using the server and client with UDP. It doesn't work.
The Server seems to run fine, but the client doesn't open the specified port. Instead it opens some very high port (5520, 5521, etc), going up to the next port every time it is closed/started again, skipping any occupied ports.
That is what happens when I'm using my own IP address(the address the server outputs) as the Client's input. Configuring the client to use IP's like 'localhost' or '127.0.0.1' don't work at all, giving me a 'Could not connect to server' error.
Either I am doing something wrong, or there's a bug here somewhere.
UDPServerClientTest.fsm
(1.57 KiB) Downloaded 1180 times
qqwy
Re: Networking & FS
Postby support » Wed Dec 12, 2012 3:27 pm
Leave it with us and we'll have a look.
support
Re: Networking & FS
Postby rlr » Thu Dec 13, 2012 12:00 am
qqwy wrote:The Server seems to run fine, but the client doesn't open the specified port. Instead it opens some very high port (5520, 5521, etc), going up to the next port every time it is closed/started again, skipping any occupied ports.
I think that's ok. Its the sender's port. The server will send it's answer back to this port
qqwy wrote:That is what happens when I'm using my own IP address(the address the server outputs) as the Client's input. Configuring the client to use IP's like 'localhost' or '127.0.0.1' don't work at all, giving me a 'Could not connect to server' error.
I'm seeing that too. I think the socket is bound to the IP address rather than 127.0.0.1
rlr
Re: Networking & FS
Postby fabb » Sun Aug 11, 2013 5:03 pm
Is there any way to configure the Flowstone Network Server to listen on "localhost" or 127.0.0.1?
It always binds to one of my external IP addresses. When I try to connect with a client from the same machine, it only works when I manually enter the IP of the Flowstone server.
fabb
