In the mood 4 sharing. My 4 VST as OSM's 4 U :)
Postby tor » Mon Sep 09, 2013 3:33 pm
I have been SM idle for a loong looong time. So I thought maybe I should share my four "finnished" plugins. Please use it freely, but credits are welcome ;)
https://www.dropbox.com/sh/wvm8bddqvby6 ... T5wVxc/OSM
Here is a tidy filter collection:
TorFilterCollection.fsm
(60.05 KiB) Downloaded 1787 times
As always credits also go to:
Andrew J for the OS toolkit.
Robert Bristow-Johnon for the EQ cookbook.
Shifrin for porting the RBJ recipe to SM code.
Trogluddite for lots of general help.
I dont remember from who I got the bode plot :/
tor
Re: In the mood 4 sharing. My 4 VST as OSM's 4 U :)
Postby trogluddite » Mon Sep 09, 2013 7:19 pm
Cheers tor - and nice to hear from you again :D
Hope you are having fun with whatever has eaten your SM time! ;)
Postby nix » Mon Sep 09, 2013 8:58 pm
thanks a million!
The eq is neat as a pin. That Kenny Buck is a great designer.
nix
Postby RJHollins » Mon Sep 09, 2013 9:21 pm
Didn't have much time to do more than take a peek inside a few of these ...
Particular interest in the EQ ... looks great !
I couldn't imagine how much time it must have taken just to wire up that one module :shock:
Thanks for letting us see inside 'tor' !!
8-)
Postby tor » Tue Sep 10, 2013 7:38 am
You are very welcome.
trogluddite: Thank you! :)
I'll be back ;)
*Edit: One more thing. You might wonder why I put the up sampling before the four first bands. It is simply because of the saturation and feedback part of the design. The four first bands process the signal in double precision and because of SM/FS limitations it is not possible to do proper oversampling there. But they work in frequencies low enough so the oversampled filter that shuffel the samples is not necessary as in the four next bands in the high frequency spectre. So every second "oversampled" sample is processed parallel.
tor
Postby tester » Tue Sep 10, 2013 2:36 pm
SM forum is damaged, so placing the file here, and the question where the discussion started:
http://synthmaker.co.uk/forum/viewtopic ... 553#p92553
Equilibre-xtract.zip
(19.85 KiB) Downloaded 1631 times
tester
Postby DjMmix » Tue Sep 10, 2013 5:41 pm
no is not damaged ... i'm open 4 osm and is run perfectly :) and thank's Tor !!
DjMmix
Postby tester » Tue Sep 10, 2013 7:55 pm
Synthmaker forum is damaged, I can't post attachements there.
tester
Postby billv » Tue Sep 10, 2013 8:42 pm
tester wrote:Synthmaker forum is damaged, I can't post attachements there.
...looks like an "on purpose modification'.
Nasty stuff for SM users...really looks like they are getting the "sqeeze"....buy FS or else..
billv
Postby tester » Tue Sep 10, 2013 9:44 pm
Or - the future of where flowstone goes. Looks that they have nobody to fix this and/or develop (php based?) websites.
tester
