strange issue (CPU)
strange issue (CPU)
Postby tester » Thu Sep 12, 2013 4:59 pm
It appears, at least on my machine, that empty schematic (static gui element only, xp sp3, c2d 2GHz), exported to exe - takes 50% of CPU (i.e. takes 1 core). Schematic itself, in Flowstone - is working correctly. Only exported exe file, in task manager, shows that high continuous CPU usage. Somewhat virtual... What interesting is, this issue does not affects real performance of streams. If I put something inside the schematic, then exported exe works fine.
Can someone confirm? Explain?
gui-cpu-test.fsm
(284 Bytes) Downloaded 1049 times
tester
Re: strange issue (CPU)
Postby TrojakEW » Thu Sep 12, 2013 7:32 pm
Looks like it is not just problem with your schematic. I have tried to export my work in progress synth to exe and result is same. 50% on idle -task manager. No problem on vst export.
TrojakEW
Postby tester » Thu Sep 12, 2013 7:41 pm
Yep, the same with VST here (works fine).
I think this needs to be reported to devs.
tester
Postby trogluddite » Thu Sep 12, 2013 9:44 pm
Very strange...
I don't see this with my latest project - it is almost exclusively MIDI and Ruby. and no default menu bar. Makes me wonder...
- Something to do with audio, (or audio menu options)?
- Ruby doesn't like it if there are no Ruby prim's?
tester wrote:I think this needs to be reported to devs.
Certainly - I can e-mail Malc directly, but I'll wait until he is back "in the office" tomorrow. Some are affected and some not, maybe a few more people post tonight and we get a little idea what is the pattern. No work for me tomorrow also - I will try a few little tests.
Postby Nubeat7 » Thu Sep 12, 2013 9:51 pm
hmm, i tried some different examples as exe export, all with the same result - cpu 50% or more!
never had a close look into exe export, are there some rules which has to be included in an exe?
Postby trogluddite » Thu Sep 12, 2013 10:14 pm
Boy, am I a dumbass sometimes! :oops:
Yes, I see the effect even with the schematic that I though was OK.
Got used to using two monitors all the time at work - in my studio, two PC's (netbook = forum, desktop = music).
Think I must have pressed CTRL-ALT-DEL on the wrong keyboard!! :roll:
I'll get that e-mail off to Malc...
... on second thoughts, maybe I should get some sleep first, before I confuse my Mum with a bug report!! :lol:
Postby Nubeat7 » Thu Sep 12, 2013 10:17 pm
tester wrote: If I put something inside the schematic, then exported exe works fine.
what you put in to work fine?
i have the same result also if there is something inside like you can see in exe export of my random keygen..
randomKeyGen.fsm
(3.82 KiB) Downloaded 1050 times
Postby tester » Thu Sep 12, 2013 10:24 pm
No, we misunderstood. Exe shows high CPU usage so or else. But this "CPU usage of an empty schematic" so to speak - does not takes the real CPU resources of the core that is processing streams (oscillators, filters, codes, asm, and so on) if I put something there. Otherwise it would be impossible to do anything due to CPU overload. So my idea is, that either this is very low priority load and/or (combined?) it affects second core (with higher streamy load I have c.a. 75-80% cpu usage here). As you know - SM/FS apps are single core, so I suspect this has to do with something interacting with the rest of the Windows. I don't know, maybe something with ruby, maybe GDI, maybne something else.
tester
Postby trogluddite » Thu Sep 12, 2013 10:29 pm
Same when there is Audio/MIDI parts too by the looks of it.
I tried with/without menu etc. and also "start audio on startup" turned off.
Think tester has the right idea - I have a few project that are meant for exe, and I never checked CPU because they always worked OK. So it looks like something that "gets out of the way" when FS is called on to do something.
Postby tester » Thu Sep 12, 2013 10:34 pm
Paraoxically - we've got serious issue - thus we've got a chance for serious update on-the-fly ;-)
tester
