Legato and other glide options
Postby djbrynte » Thu Oct 31, 2013 8:09 pm
What is an legato and how do i add such function and are there other glide options i can add?
djbrynte
Re: Legato and other glide options
Postby billv » Thu Oct 31, 2013 9:19 pm
This gives good explanation for legato...
.http://en.wikipedia.org/wiki/Legato
Access legato/glide or port, by going in the "midi to poly module", open small module
called 'portamento'...inside is small knob, and a on/off switch.
billv
Postby nix » Fri Nov 01, 2013 12:21 am
It sounds like legato does not have separate notes.
That is a great Wiki, ta bill 8D
There is only one attack and decay phase within the tie.
The first note attacks, and last decays.
All the notes within the tie slide without changing volume.
Any thoughts on implementation peeps?
I'll think about it too.
nix
Postby djbrynte » Fri Nov 01, 2013 4:29 am
Dident understand everything what do i change in The midi to poly module?
djbrynte
Postby billv » Fri Nov 01, 2013 5:12 am
djbrynte wrote:Dident understand everything what do i change in The midi to poly module?
i don't blame you...i forgot to mention the important part...MONO..... :lol: :lol:
Legato.fsm
(138.31 KiB) Downloaded 960 times
billv
Postby djbrynte » Fri Nov 01, 2013 11:44 am
Thnx
djbrynte
Postby CoreStylerz » Fri Nov 01, 2013 12:15 pm
Here a glide example.
Glide.fsm
(22.61 KiB) Downloaded 954 times
PM me if you are interested.
CoreStylerz
Postby djbrynte » Fri Nov 01, 2013 7:02 pm
thnx alot guys i will send the file to you soon corestyler. About the LFO display.
djbrynte
cron
