A new chorus-like effect
Re: A new chorus-like effect
Postby tektoog » Sun May 10, 2020 6:46 pm
Hey,
Thanks Martin!
It sounds pretty good!
A good add to the FS sonic arsenal ;) :D
tektoog
Re: Yet another Chorus
Postby Spogg » Mon May 11, 2020 1:47 pm
martinvicanek wrote:Yet another chorus effect. This one is pretty much straight forward: a configurable number of echos (up to 100) with random detunig and panning. It is a bit CPU hungry when you go to 100 voices but I like the sound.
This sounds great Martin. :ugeek:
I get a max of about 3.2% on my PC (all voices) in FS, which is fine considering the richness of the effect. I found I can get an unusual flangy sound too.
I like this very much.
A question…
The number of voices chosen affects the CPU usage. I presume this means that some code isn’t run with a lower number set. I’m not an ASM expert but I know enough to get into trouble, so how do you achieve such a thing in ASM? Or is the number of loops run in a single sample?
Thank you for yet another great module.
Postby adamszabo » Mon May 11, 2020 2:07 pm
The loop in the assembler increases the cpu with each count. Its essentially the same as you would write each delay code separately and activates each as the count increases
adamszabo
Postby Spogg » Mon May 11, 2020 4:30 pm
Thanks Adam!
Postby BobF » Mon May 11, 2020 5:05 pm
Very nice Martin!
Take care, BobF.....
BobF
Previous
