Program not working when in background
Postby frank-riedel » Wed Nov 07, 2012 4:10 pm
Any help to get it working when not in focus ??
Frank
frank-riedel
Re: Program not working when in background
Postby chackl » Wed Nov 07, 2012 4:15 pm
Do you mean flowstone or an exported EXE?
What kind of shematic did you use? Is it a shematic with timing?
chackl
Postby frank-riedel » Wed Nov 07, 2012 4:18 pm
the exported .exe
I have attached the shematic
Joystick.fsm
(17.18 KiB) Downloaded 1168 times
frank-riedel
Postby chackl » Wed Nov 07, 2012 4:22 pm
Ill try at home i have no joystic here at me at the moment ;)
chackl
Postby frank-riedel » Wed Nov 07, 2012 4:24 pm
Looking forward to your reply ;)
Regards
Frank
frank-riedel
Postby chackl » Wed Nov 07, 2012 4:54 pm
Well same Problem at me.
What Windows Version do you use?
chackl
Postby frank-riedel » Wed Nov 07, 2012 4:57 pm
Windows 7 32 and 64bit
frank-riedel
Postby chackl » Wed Nov 07, 2012 4:59 pm
Ok sorry to tell, but i fear it is no Flowstone Problem.
It seems to be a Problem on Windows 8 that the HID deviced Need a Focus on the Programm that the HID date of the Joystik Comes trough.
If you go to Devices ans rightklich on your stick as select "Settings" and then Properties you get the Joystic konfig of Windows. If you un-focus this Windows the data of the stick is not provided to the Programm it seems.
EDIT you just said you have win 7. Ok well maybe there are also Problems with 64bit because i did something similar on Win7x86 some time ago.
chackl
Postby frank-riedel » Wed Nov 07, 2012 5:01 pm
anyway to get arround this problem ??
frank-riedel
Postby chackl » Wed Nov 07, 2012 5:08 pm
frank-riedel wrote:anyway to get arround this problem ??
Well midi Controllers don't have those Problem. But in normal case midi Controler are not designed to use as a Gamecontroller.
Korg hast this "Korg Nano" Line - This Controllers are not verry expensive and not as great. Another would be a phidget Input, but i don't know much about that yet.
Regards
chackl
