Routing Matrix
Routing Matrix
Hi All !
Is it possible to save Routing Matrix settings with the preset/program ,because now when change preset in Preset Manager the settings of routing matrix remain the same .
Thanks in advance
Thanks in advance
Re: Routing Matrix
Hi!
You need to give the 'preset parameter' modules a unique name.
by default they are all labelled 'Source' and 'Target'
This is necessary for all parameters in a build you would like to be recalled as presets
Hope helps!
Hope helps!
Re: Routing Matrix
Thanks for your help nix .I have give different name when start work with this module ,but change only the mark (v) in drop list menu and not all the name when change the preset from preset manager
Take a look in Schematic and if you can help me thnx a lot !!
- XvSynth1b.fsm
- Vsti with routing matrix
- (226.93 KiB) Downloaded 850 times
Re: Routing Matrix
Yet it is exactly as Nix said. I looked at your schematic and all of the preset parameters have their initial names (source target). The matrix itself also has preset parameters, which you also didn't rename to unique ones. Just give them all unique names, and update this thread with the new schematic, should you still have issues thereafter.
Re: Routing Matrix
Thank you tulamide, but I make all this and don't work the module as I need ,only check the selection when chance programs and not ! show it, in drop list as need to work the module .Need some extra connections !!! to work good like matrix routing as it says ..lol. When make it I post it again here
