Legato and other glide options
ISounds
Post by ISounds »
What is an legato and how do i add such function and are there other glide options i can add?
Re: Legato and other glide options
Post by billv »
This gives good explanation for legato...
.http://en.wikipedia.org/wiki/Legato
Access legato/glide or port, by going in the "midi to poly module", open small module
called 'portamento'...inside is small knob, and a on/off switch.
nix
Post by nix »
It sounds like legato does not have separate notes.
That is a great Wiki, ta bill 8D
There is only one attack and decay phase within the tie.
The first note attacks, and last decays.
All the notes within the tie slide without changing volume.
Any thoughts on implementation peeps?
I'll think about it too.
ISounds
Post by ISounds »
Dident understand everything what do i change in The midi to poly module?
Post by billv »
djbrynte wrote:Dident understand everything what do i change in The midi to poly module?
i don't blame you...i forgot to mention the important part...MONO..... :lol: :lol:
Legato.fsm
(138.31 KiB) Downloaded 1043 times
ISounds
Post by ISounds »
Thnx
CoreStylerz
Post by CoreStylerz »
Here a glide example.
Glide.fsm
(22.61 KiB) Downloaded 1034 times
PM me if you are interested.
ISounds
Post by ISounds »
thnx alot guys i will send the file to you soon corestyler. About the LFO display.
