Flowstone with RS232
Discuss Control Systems here
RZK
Post by RZK »
Hi everybody. I use flowstone to communicate with a marking machine. I use a port COM but it send all data in data connection even if I use a trigger switch with a button.
To stop the machine I maked a new port com to send the stop command(i don't find another solution). I communicate in hexadecimal language with the machine.
Other think, i can't receive information from the com port in RS232. How can I get that informations ?
If you need other information please do not hesitate to contact me.
help?
briant1972
Re: Flowstone with RS232
Post by briant1972 »
I wrote a Flowstone program to communicate with a cheap Koyo Click PLC using RS-232 MODBUS RTU and it works fine. Let me know if you still need some help.
RZK
Post by RZK »
ACD Marquage2.fsm
(17.15 KiB) Downloaded 4427 times
My machine give anwser correctly, thanks. My problem now is to make a trigger "return to zero" of "deplacement manuel" zone. I can up and down the position of my stylet on x and y but its impossible to return to zero. i tried to make the return to zero but when i press on x+ or x- or y+ or y- the label come back to the anterior position.I know what is the problem i think it's my sample and wait but i don't know how to solved it ... i know nothing in ruby.(i have deleted the trigger "return to zero" result of not working. Sorry for my English ^^
http://imageshack.com/a/img38/6416/7fa8.png (where the problem is (i think ^^))
Post by Nubeat7 »
you mean a zero trigger like this? watch inside the module you showed in the picture
ACD Marquage2 (1).fsm
(17.4 KiB) Downloaded 4380 times
RZK
Post by RZK »
thanks a lot Nubeat7 its what i searching for. I passed 5 hours on it.
Post by Nubeat7 »
great to hear, you`r welcome.
