anti-rush blocker, timers, overload
As suspected - ruby crashes application in automation mode, if it receives too many triggers at once in certain looped wiring. Solution - temporal trigger blocking. Simple module like below. But there is one small problem.
While it works perfect during automation mode - after you stop playback - you need to wait over 10 seconds (on my machine) - before the "antirush" unblocks output. It appears, that too many triggers at once are queued to the timer, and this overloads the wiring.
So - can this be done differently? Some time measurement based perhaps instead of firing the timer?
- antirush.fsm
- (435 Bytes) Downloaded 1013 times
Re: anti-rush blocker, timers, overload
Inside the schematic - antirush3 seems to work almost as it should be. It blocks triggers during automation, it isn't overloading the timer, but...
It's interesting. When the "test plugin" is in no-automation mode (Reaper) - everything works fine. But when "plugin" has automation on array element - then even at slow clicking and "no playing" mode - very often (each 5th or so) pass-through trigger is missing... antirush v2 inside the schematic - seems to suffer from the same issue.
Any ideas how to approach it?
- antirush-1.fsm
- (1.57 KiB) Downloaded 1012 times
4 antirush solutions. I see no way without some sort of timer or ticker.
Now it's time to check whether are there other places to place it...
- antirush-2.fsm
- (1.64 KiB) Downloaded 998 times
Is there a way whether changed values are coming from DAWs automation? I mean - some sort of bool indicator, when values are not changied manually, but are driven by DAW automation.
maybe i dont understand what you are talking about but this starts to confuse me, it looks like you are talking about a fictional problem, trojakEW couldn`t examplified any ruby crashes, and for what you are talking, a normal redraw limiter should solve it,tester wrote:ruby crashes application in automation mode, if it receives too many triggers at once in certain looped wiring
the preset module from the stockknob is build that it prevents triggerloops, automated data (from host) which comes out from presetparameter to knob -> from knob to presetparameter input, this triggerloop is locked with the interaction boolean and 2 triggerswitches.
when automated data comes from presetparameter primitiv, the knob is updated with a redraw limiter which shouldn`t be a problem for ruby (i never had), so where should this triggeroverload happen when you build it like this?
would be nice but not that i know..tester wrote:Is there a way whether changed values are coming from DAWs automation? I mean - some sort of bool indicator, when values are not changied manually, but are driven by DAW automation.
When I use automation with my multifunction editbox, where values are looped back due to undo/redo system and refreshing routine (so that view match output) - on automation - it crashes. But it also crashes on automation when I blocked triggers within the editbox module, and had on output - simple text viewer, to see how the array is refreshing (forgot about redraw limiter here - maybe this caused second part of the problem).
Anyway I'm checking for some sort of universal option for limiting amount of triggers per second, that will work for both - flood of triggers coming from automation, and manual updates (user clicking, external field, and so on).
So it's a "case in progress" so to speak. But I think I found a way. I probably can combine antirush 1 with antirush 4 (limit triggers per second + blocking if triggers happen too often; first part should act as an anti-flood the timer).
The thing is - how to block undoredo during automation cycle.
It appears, that "antirush 2" from template can be arranged here, to make it work fine. But I noticed interesting thing regarding Reaper. After plugin is loaded - everything works normal. After automation is set for whatever node - things work "almost normal" (sometimes some global triggers fail to pass through), but when all automation envelopes are removed - plugin's node is not released. So I'm marking this thing to investigate it somewhere in the future.
